I’ve got a 2010 2 Wheel Dr. access cab my AC is blowing hot But gauge says system is full help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mejbr2003, Jul 19, 2021.
  1. Jul 19, 2021 at 9:52 PM
    Mejbr2003
    Mejbr2003 [OP] New Member
    2010 Tacoma access cab
    If my system is full of refrigerant why is my AC blowing hot or warm I should say I hear the engine idle change when I turn the Aceon so what’s going on any ideas
    Geeves77 likes this.
  2. Jul 19, 2021 at 9:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did you check it with service gauges or just one of those "suicide cans" from the parts store?
    TnShooter and 12TRDTacoma like this.
  3. Jul 19, 2021 at 10:36 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Just because it’s charged doesn’t mean it will work. You still need a functioning pressure switch, compressor, compressor clutch assembly, AC amplifier, MAG clutch relay, and blower fan. Check all them and report back.
    TnShooter, 12TRDTacoma and Dm93 like this.
  4. Jul 19, 2021 at 10:49 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Did you compare gauge readings with the service manual? Chances are it’s just low on Freon, but not low enough to stop the compressor from turning on
    12TRDTacoma, Dm93 and 6 gearT444E like this.
  5. Jul 19, 2021 at 11:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A lot of factors here. And a lot of good tips in here from various members. To echo what they have said, ensure the blower actually works and that the compressor turns on when checking your system. If they are, then ensure the pressures are not too low using a proper AC machine to do so. If you did use the "AC system suicide by can" to fill your system up then you better suck it all out and try again. If all this has been done then you will have to dig deeper and check the pressure switch, AC amplifier, HVAC climate control module itself.
    Also, be aware that these 2nd gens in stock form cannot operate the AC in hot weather 90* and up to save their lives. If it is non op only at idle and on a very hot day, then there is actually nothing wrong here.
    6 gearT444E likes this.
  6. Jul 20, 2021 at 9:26 AM
    Mejbr2003
    I checked it with the suicide cans gauge I did not fill it from the suicide can I’ll have to look into it further thanks so much for all the tips
  7. Jul 20, 2021 at 8:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It could also be over filled....
    CurtB and 6 gearT444E like this.
