I accidentally hit the switch for the electronic LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Arminius, Feb 13, 2015.
  1. Feb 13, 2015 at 10:35 AM
    Arminius
    Arminius [OP] Member
    Texas
    2011 4banger PreRunner
    I had to get something out of the little pop-out drawer on the lower left dashboard and accidentally hit the switch to disengage the normal traction control and engage the electronic LSD. I was going way faster than you're supposed to when you engage it. About 45 MPH. As soon as I noticed I hit the switch again to set things right. It was maybe 2 to 3 minutes before I noticed the idiot light.
    Do you think I hurt anything?
  2. Feb 13, 2015 at 10:37 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Drive it around some, your truck will tell you if you hurt it or not.
  3. Feb 13, 2015 at 10:38 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Fine
  4. Feb 13, 2015 at 10:41 AM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Only thing it does is use your rear brakes to simulate a mechanical LSD... only time that works is when your wheels spin at different rates
    There is no max speed for it
  5. Feb 13, 2015 at 11:19 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the vsc turns back on at 35 mph if you just tapped it.... theres no harm you can cause by pushing that button while moving.
  6. Feb 13, 2015 at 11:21 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    LSD/Traction control is what he hit
    VSC is a 3-5 sec hold to turn that off, different button
  7. Feb 13, 2015 at 11:42 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    If the roads are wet/snow covered at all I always use the electronic LSD. The auto-lsd mode works great, not to mention I cannot stand when the electronics regulate the engine output as it does in the standard operating mode.
    As stated above you can use it at any speed.
  8. Feb 13, 2015 at 11:54 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Me too. Snow or rain and I hit that button before I go anywhere.
    Unless I'm using 4-Hi, in which case it's already that way anyway.
  9. Feb 13, 2015 at 12:15 PM
    OZ-T
    Peter North
    British Columbia
    uh no
  10. Feb 13, 2015 at 1:50 PM
    js312
    Joe
    New England
    ...and only while stopped (at least for my 2011)
  11. Feb 13, 2015 at 9:48 PM
    OZ-T
    Peter North
    British Columbia
    Thanks for your neg rep however it's your post here that is inaccurate and worthless , it's the same button duh
  12. Feb 13, 2015 at 9:52 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Dang. Dinged for being quick on the draw OZ?
  13. Feb 13, 2015 at 9:58 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    The electronic LSD is always on unless you push and hold that button.
    When the button is not pushed you still have eLSD but the rear tires will only move as fast as the truck can. When you push the button, it no longer limits the power to wheels that are spinning without traction so you can give it more gas and both wheels will spin whether the truck is moving fwd or not.
  14. Feb 13, 2015 at 9:59 PM
    Pigpen
    Dan
    Northwest Montana
    There ya go, Oz
  15. Feb 13, 2015 at 10:02 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Yah what this guy said. You should just keep hitting buttons, worrying about it and post on here OP instead of reading your manual.
    I mean it's not like any of us have anything better to do on a Friday night.:jerkoff:
  16. Feb 13, 2015 at 10:20 PM
    OZ-T
    Peter North
    British Columbia
    Mange la merde Christian
  17. Feb 13, 2015 at 10:32 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I hope your happy, just look what happened..
  18. Feb 14, 2015 at 8:26 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Probably not a big deal - I drove 5 miles in 4hi when the road was dry and clear of snow, luckily didn't exceed 60mph. Toyotas can tolerate user error to a minor extent.
  19. Feb 14, 2015 at 9:41 AM
    js312
    Joe
    New England
    You can exceed 60 while in 4 HI without a problem, just not to engage it. Dry pavement is that bad part of that.
  20. Feb 14, 2015 at 7:21 PM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    You're welcome... Open your owners manual, then take the foot outta your mouth
