I accidentally put 91 Octane at 2500 miles on a taco that's used to 87
Discussion in '3rd Gen. Tacomas (2016-2023)' started by N2DesignsInc, Jun 19, 2018.
  1. Jun 19, 2018 at 9:27 PM
    N2DesignsInc
    N2DesignsInc [OP] --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Disclaimer - I am not knowledgeable about the fuel relationship to an engine, compression, etc so go easy fellas and I will love you long time!
    With that said, I am not used to pumping 87 because all my past vehicles for over a decade now have been 91, but I wasn't thinking today and have never used 91 Octane on my new '18. I've always put 87...now I know the manual says 87 or higher, and I don't care about performance, mileage or anything of that sort, so this is not a fuel discussion of that type, but rather a question about the following:
    - Why does the manual say "Fuel Type: 87 (Research 91 octane) or higher"?
    - When you start using one fuel type, is it true that you must stick to it and not flip flop back 'n' forth?
    - What do they mean "Research 91 Octane"?
    - What are the draw backs of accidentally putting a higher octane on a vehicle used to 87?
    - Does this mess with the ECU's learning at this stage (2500 miles)?
    - Can I switch back to 87 after this tank?
    - If so, can I wait until I'm on Empty or should I dilute it with lower octane 87 at the half way point?
    - With higher octane, does the engine run harder? Hotter?
    - Does it put stress on the engine or does the ECU manage this?
    - Does my ECU get confused now and need to learn my fuel type WITH my driving habits?
    I know I'm over thinking this, but part of this is a learning experience, and the other part is that I would like to sleep tonight, can you guys help me sleep tonight lol! Thanks in advance!
    Again, I don't care about performance, mileage or anything other than not hurting my engine, EVEN if the manual says its ok...some of you guys have better experience, plus the manual doesn't say whether you have to stick to one or can flip flop.
    polloloco81 and DA3 like this.
  2. Jun 19, 2018 at 9:33 PM
    Avail211
    Avail211 Well-Known Member
    2016 BBP TRD OR
    remgu2000, TomTwo, Intrepid and 2 others like this.
  3. Jun 19, 2018 at 9:34 PM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    I think youre over thinking it honestly. Putting higher octane gas in something that doesnt require it, is just throwing money away. Only high compression engines that are tuned for higher octane benefit from it because the piston can compress a higher octane fuel and air mixture without preignition happening. If you put 87 in a sports car that requires higher octane, you get preignition and it runs like shit. The piston detonates before it hits the top dead center of its cycle because lower octane fuel cant be compressed as much as the higher octane can. Thus you lose potential hp and get worse gas mileage. Some newer cars can actually take anything with the computer adjusting. Its just stupid when you see fake ballers at the gas station buying 87 in their german luxury cars because theyre too broke/cheap to buy the higher octane they require
    synaps3, Snowman, Intrepid and 10 others like this.
  4. Jun 19, 2018 at 9:38 PM
    Avail211
    2016 BBP TRD OR
    Google says RON (Research 91 octane) is everywhere but the US: https://www.etuners.gr/fuel/
    ETA: Bottom line, don't worry about it. Fill it up with 87 whenever you want and go about your day, it's not going to hurt anything but your wallet by putting a tank of higher octane in. Some will say it makes their truck faster or smoother, others will say it doesn't make any noticeable difference. I've never wondered or cared since premium is on average .50 more per gallon so I don't get it, and my truck runs fine as-is.
    synaps3, hiPSI, INSAYN and 1 other person like this.
  5. Jun 19, 2018 at 9:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Only thing that happens is the engine can run a bit more timing and you may feel a bit more pep. No big deal and you can run 87-89-91-92-93, hell you could pour 110 in if you could find it.
    aeok18109 and N2DesignsInc[OP] like this.
  6. Jun 19, 2018 at 9:55 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Your engine is an air pump. Think of a syringe, when u pull it back it draws in air (and fuel). When you push it in (with the tip closed), the air / fuel mixture compresses, just before the syringe closes fully, a spark plugs ignites the mixture sending the syringe back the opposite direction, drawing more fuel / air in and the process continues. Theres only so much you can compress this mixture before it'll combust under it's own heat / pressure, before the spark plug has a chance to ignite it. That's where octane ratings come into play, octane rating is basically how much you can compress it untill it ignites on its own. On high performanc engines, the heat / pressure inside the "air pump" are greater and require a higher octane rating. On our engines, 87 (the lowest as far as I know) is fine. If you run higher, it just means it's less prone to self combustion, the spark plug will still do it's job as it was told. This turned into a long ramble. Hope it helped :rofl:
    joerod86 and N2DesignsInc[OP] like this.
  7. Jun 19, 2018 at 9:55 PM
    N2DesignsInc
    Los Angeles, CA
    Guys for the record my goal is not to run 91, so throwing away money or not really doesn’t matter to me at the moment, rather how it affects my engine when an accident like this happens and I want to go back, so I am asking from a technical stand point, not performance or MPG gains or losses, but you guys are right about that, why do it if it’s not a high performance engine...I knew what I was getting into when I bought the truck and it wasn’t about getting mileage or speed.
  8. Jun 19, 2018 at 9:57 PM
    N2DesignsInc
    Los Angeles, CA
    Not a ramble, you just seriously educated me. The longer the explanation the longer and better I will sleep tonight! Thanks guys!
    aeok18109 likes this.
  9. Jun 19, 2018 at 9:59 PM
    N2DesignsInc
    Los Angeles, CA
    Saw this thread and decided I didn’t want to hear him out lol, was happy with 87 for as long as I own the vehicle. The cost difference is so small to me that I really don’t care about the money, just treating my truck right in the beginning for it to last me a long time!
  10. Jun 19, 2018 at 10:12 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It doesn’t matter what you run. The ecu will adjust any timing issues. You didn’t do any hurt to your motor or truck. You can sleep well
    cblow5 and OnHartung'sRoad like this.
  11. Jun 19, 2018 at 10:18 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    The only time I put higher octane is when I am towing and know ahead of time that my route will have steep grades. Otherwise, its ok to mix and switch based on your needs.
    Edit: I’ve also mixed grades with no issues when the lowest is below 87, sometimes happens in places where they only have two choices like in Baja California - gas or diesel.
    cblow5 likes this.
  12. Jun 19, 2018 at 10:26 PM
    Avail211
    2016 BBP TRD OR
    Nah you're good man, I wondered the same things you asked when I was younger. I was given a lot of bad info and didn't have the internet to figure it out on my own/ask someone, so I'd heard the same rumors you were asking about in your 1st post. I remember hearing at 16 that putting higher octane in=faster car, but meant you had to stick with it forever afterwards otherwise I'd F stuff up. Learned later on that unless the manual states higher octane, 87 is perfectly fine, and switching between octanes doesn't do shit except cost more money.
    Yeah yeah I know some will say that putting 93 in will turn this boat anchor of a truck into a Corvette and get 300mpg, but I doubt it.
    hiPSI likes this.
  13. Jun 19, 2018 at 11:01 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    You can bounce back and forth with octane amounts any time at all and your truck will adjust as necessary. No worries there. Mixing octanes is fine. The truck will do what it needs to do to adjust and it'll be happy.
    For what it's worth... when I run 87 in my 2nd gen (2014), I get pinging when going up hills until the auto trans downshifts (or until I force it to downshift if it doesn't do it on its own). When I run 91, I don't have the problem.
    Brodozer69 likes this.
  14. Jun 20, 2018 at 3:06 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Lots of good points, also worth noting that gas stations usually only have 2 tanks, one with 87 and the other with 93. If you buy 89 or 91 it just mixes from both tanks to hit the midgrade octane.
    Obviously if you get ethanol free gas it'll be from its own tank.
  15. Jun 20, 2018 at 5:01 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Your truck is going to blow up. I'm sorry.
    Seriously, nothing is going to happen. When you switch back, just switch back. The truck will take care of the rest.
    Intrepid and rmepilot like this.
  16. Jun 20, 2018 at 5:33 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    Is this thread a joke?
    Shmody, Sig45, Aw9d and 6 others like this.
  17. Jun 20, 2018 at 5:40 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    From an engineering and practical view - nothing happened that would adversely affect your truck in any meaningful way when you ran 91. You can switch back to 87 any time.. or not, with no issues. Quit worrying and enjoy your truck lol.
  18. Jun 20, 2018 at 6:01 AM
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    your truck is fine....you can switch at will, its not going to harm anything...
    regarding "research ocatane"
    there are actually 3 octane scales......RON, MON, and PON.
    RON = Research Octane (what they use in Europe)
    MON = Motor Octane
    PON = Pump octane (What we use in the US, you will see it listed on the pump as R+M/2)
    now the fuel is all the same.....RON and MON are both measured octane values in a lab setting( but under different conditions), RON values are always higher than MON values.....PON is the average of the RON and the MON.
    so:
    87 Octane in the US = 91 Octane in Europe
    91 Octane in the US = 95 Octane in Europe
    93 Octane in the US = 97 Octane in Europe
    the fuels are exactly the same, just measured differently
    this also gives rise to the myth that they have higher octane fuel in europe, and that American stuff is "watered down"........its not......thats like saying 212*F is hotter than 100*C
    ddettamanti and hiPSI like this.
  19. Jun 20, 2018 at 6:04 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Define "hot"....:p
  20. Jun 20, 2018 at 6:04 AM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    Just don't put diesel in it and you'll be fine.
    BSFord, tonered and hiPSI like this.
