I added helper springs, do I need to change WDH settings?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Roscoe Taco, Oct 1, 2020.
  1. Oct 1, 2020 at 8:14 PM
    Roscoe Taco
    Roscoe Taco [OP] Sort of old guy
    Ron
    Southern NM
    2017 Tacoma TRD OR 4x4
    My weight distribution/anti-sway hitch was set up with trailer level. Yesterday, I had some helper springs added to make the ride a little firmer when towing and to help with weight in the truck bed. The helpers were adjustable so I had them set for 1000 lbs. I haven’t noticed any significant difference in the ride with empty truck bed and no trailer nor does the rear appear to be raised.
    I have not hooked up the trailer since installing the helpers so don’t know yet if the trailer will still appear level when attached. Does anyone know, will I need to make adjustments to the WDH?
  2. Oct 1, 2020 at 8:29 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Yes. At least that's what Roadmaster says on their website. So i did.
  3. Oct 2, 2020 at 6:01 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Changing your rear spring rate - including adding helper springs - means the rear of the truck will be under a different height or tension under the WDH.
    You need to readjust it.
    Depending on the weight of the trailer, there may be no adjustment. In my opinion, if you have sumosprings / timbrens or helper springs or a smaller trailer, you do not need a WDH. I've been fine without one and I'm running Dakar heavy leafs with sumosprings.
