I am a 4wd newbie
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buffco, Jul 16, 2011.
  1. Jul 16, 2011 at 8:19 PM
    Buffco
    Buffco [OP] Well-Known Member
    My dad always thought 4wd was a waste of money. Well, the 99 Taco I just bought is a 4wd, so there.
    But problem is, I know precious little about it, except the few things I've read like not running in 4wd on pavement.
    I have a potentially very stupid question. When 4wd is engaged (but the hubs are NOT locked in) does this essentially "gear down" your transmission? Can putting your truck in 4wd (again, withOUT the hubs locked in) be used for "granny-gearing"?
  2. Jul 16, 2011 at 11:45 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    In Low Range, yes... In High Range the gearing is the same as in 2WD. On older 4WD's (some) you can find a 2-LOW position (unmarked) in the shift pattern of the transfer case shifter. My friend had a 1972 Jeep CJ-5, and loved to play trucker, and run through the gears in 2-LOW before going to 2-HIGH... LOL
    There is TON's to read on 4WD... on the Internet... It is no waste of money IF you go places where only 4WD can get you to (or back from)!
  3. Jul 16, 2011 at 11:50 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    In no circumstances engage 4wd on dry or wet pavement.
  4. Jul 16, 2011 at 11:56 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    X2...Bush agrees with the bus driver,"No 4x4 on pavement!!".
  5. Jul 17, 2011 at 4:22 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    Congratulations on your new ride!
  6. Jul 17, 2011 at 5:35 PM
    David K
    Only use 4WD when you NEED to (ie. the rear tires are spinning and you are not moving... but never wait until you are stuck to use, use every time you are off pavement to lube the parts, if nothing else)... Now the key is NEEDING TO USE IT, A LOT!
    Have fun!
    See the Mision Santa Maria trip pics link, below...
  7. Jul 17, 2011 at 5:39 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Not stupid question at all, and yes, you can use low range with hubs unlocked. Don't be flooring the gas pedal with it in this mode because of the torque multiplication in low range. You could break things if you are rough on it.
    Used to use "2lo" all the time when I had a truck with manual hubs. Wish my 2nd gen was that simple.
  8. Jul 17, 2011 at 7:02 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    WHat year truck do you have? The locked vs not locked is a non-issue if you've got auto-locking hubs. As for never using them on pavement, it's not so much the pavement as the turning, in other words don't use them on the pavement and try to turn with 4x4 engaged. You should use it every now and again just to keep things lubed up, the owners manual recommends doing this so if you have a stretch of straight road or even a big, empty parking lot put things into 4 hi and drive a little. Depending on the model you have you can shift out of 4hi while driving, in mine the drivers side visor has the speeds you can shift into and out of 4wd.
  9. Jul 17, 2011 at 7:10 PM
    Buffco
    See my sig. It's a 99. Manual hubs.
    Are you saying to engage 4HI, but leave the hubs free-wheeling to lube everything?
  10. Jul 17, 2011 at 7:20 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    A good thing to do is get a couple of buddies with a 4wd and get them to show you around and some of the basics. Its alot of fun, just tread lightly and drive easy.
  11. Jul 17, 2011 at 7:39 PM
    Buffco
    I have no friends, so, yeah.... That's a problem.
  12. Jul 17, 2011 at 7:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This is correct.....;)
  13. Jul 17, 2011 at 11:15 PM
    David K
    I am saying USE your 4WD as much as you can, since you got one... In other words, discover the great outdoors and go four wheeling!:D
    If you don't lock the hubs, then you are not lubing everything!
  14. Jul 18, 2011 at 12:57 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
