I AM BRUTICUS (build thread)
Discussion in '2nd Gen. Builds (2005-2015)' started by alvinfromhawaii, Mar 9, 2016.
  1. Jun 28, 2019 at 10:33 PM
    #241
    alvinfromhawaii
    alvinfromhawaii [OP] Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    Upgraded to Alpine Halo 9
    Loving this new head unit. 9" screen is amazing. The best thing is no more glare from the sun. Great combo with the Infinity speakers. The unit comes with Apple Carplay, Bluetooth connection, anytime rear camera display, HDMI input and maintains all the OEM controls and functions. Sound is much stronger and clearer. Looking to add an amp in the future. Also now there is a cubby for a CB hopefully.
    Biggest pain on the install was trying to get all the wires to fit behind the unit. With all the additional harnesses and Maestro control units, it barely fit. I'm not looking forward to ever pulling it apart. Eek.
    Here is a thread on the unit for those interested.
    https://www.tacomaworld.com/threads/alpine-halo9.542412/
  2. Jun 28, 2019 at 10:39 PM
    #242
    alvinfromhawaii
    Northern California
    Doing Some Cutting
    Getting ready for the fender chop...
    HIghlande2 and Soul Surfer like this.
  3. Jun 28, 2019 at 10:52 PM
    #243
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
  4. Jun 28, 2019 at 10:52 PM
    #244
    nudavinci64
    Robert
  5. Jul 18, 2019 at 10:09 PM
    #245
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    Interesting sun shade. Who makes it and where did u get it?
  6. Nov 17, 2019 at 5:40 PM
    #246
    alvinfromhawaii
    Northern California
    Sorry for the late response. It is a covercraft UVs100 custom sunscreen.
    Bravisimo[QUOTED] likes this.
  7. Dec 2, 2019 at 8:09 AM
    #247
    Bravisimo
    Joe
    Santa Clarita, CA
    awesome thank you!
  8. Dec 20, 2019 at 6:15 PM
    #248
    alvinfromhawaii
    Northern California
    BAMF Tacoma Front bumper reinforcement brackets
    Upgraded the Pelfry brackets with the BAMF @JLee brackets. They are beefy and easy to install. Used a floor jack to support the bumper when bolts are loosened. The first side was a little tight (a little grease and a rubber mallet did the trick) so make sure you leave the bolt inside the bumper tightened so that the bumper doesn't separate from the frame (this will make fitting the new bracket over the bumper and frame easier). Also before putting on the new bracket, remember to take off the old "L" bracket from Pelfrey, they don't work together.
    Old "L" Bracket (located on the back of the frame, sandwiched against the shock reservoir mount)
    New Bracket
    Note: You will need to remove these frame covers (Back, Front) for the top bolt to go through. I had to break the one pictured here to get it out. The other one pops out easily w a tap from this hole once the cover is removed.
    Bravisimo likes this.
  9. Apr 6, 2020 at 12:00 AM
    #249
    alvinfromhawaii
    Northern California
    Expedition Essentials' SwitchPros Mount
    https://expeditionessentials.com/products/switch-pros-mount-toyota-2nd-gen-2005-2015
    This mount was made for the newer touch controller (Flush mount 8100 and 9100) Older SP8100 controllers are of a slightly different dimension so it doesn't quite fit through this mount opening. In order to get this to work, I had to add 1/4 aluminum spacers to mount my SP8100 surface mount version of the controller.
    You will also need to create an opening that allows the movement of the cable when opening and closing the sunglass holder compartment
    You will also need to create a temple to figure out where to drill the holes for the mounting screws
    Final installation
  10. Feb 18, 2021 at 5:03 PM
    #250
    alvinfromhawaii
    Northern California
    Finally, Rear High Clearance Bumper
    After about a year sitting in my garage, I was finally able to install the Bruteforce Fabrication High Clearance Rear Bumper with Dual Swingouts. It was a used bumper from another Tacomaworld member. It was in decent shape but needed new swingout bearings, a new swingout latch, and paint restoration. The bumper has also made the ride of the truck more solid, especially on the freeway. The truck now feels like it is planted firmly on the road. Since removing the swaybar a while back, the truck has been squirrelly at high speeds. Now with the bumper, it feels solid.
    You can also see in the pictures a teaser of the rear fenders cut and fitted with trimmed bushwhackers. More on that in a later post.
    Bumper prior to paint restoration. Video to come on the spindle replacement in a later post.
    Bumper all polished up and some new taillights. Also trimmed the fenders and installed the Bushwacker
    fender flares before the install to make things easier. More on the fender trim in a later post.
    The fender cut came out straight. I'll talk more about how I did it in a future post and possibly a video of it.
    Restored the paint using some Turtle wax polish to remove the oxidation and water spot build-up. It's holding up ok. I may have to use polishing or rubbing compound to really get it looking good. Gonna have to be careful to not get the bumper to shinny from the polishing compound.
  11. Feb 18, 2021 at 5:20 PM
    #251
    nudavinci64
    Robert
    Time to cut that tail pipe
  12. Feb 18, 2021 at 5:43 PM
    #252
    alvinfromhawaii
    Northern California
    Yeah, that’s next on the list.
    nudavinci64[QUOTED] likes this.
  13. Feb 18, 2021 at 9:03 PM
    #253
    nudavinci64
    Robert
    :sawzall::sawzall::sawzall::sawzall::sawzall::sawzall:
  14. Mar 7, 2021 at 11:35 PM
    #254
    alvinfromhawaii
    Northern California
    Alpha Rex Pro tail Lights (Jet black)
    First impressions. Nice light design that is different from anything out there, solid build, high-quality material, comes with a 2-year limited warranty from TacomaBeast. I think I may eventually want to switch to the red versions to keep it to a more OEM style.
    nudavinci64 likes this.
  15. Mar 7, 2021 at 11:42 PM
    #255
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Transformers fan?
  16. Jul 14, 2021 at 10:12 AM
    #256
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    In for more details about that bumper...! ;) :thumbsup:
  17. Jul 14, 2021 at 11:52 AM
    #257
    nudavinci64
    Robert
    Bruteforce Fab Dual Swing out. Rocking the same great shop and great price.
    alvinfromhawaii[OP] likes this.
  18. Aug 12, 2022 at 2:05 PM
    #258
    alvinfromhawaii
    Northern California
    Upgraded window switches
    Saw a post from @nudavinci64 on these awesome switches. I now have auto up and down on all 4 windows plus nighttime illumination. Kit comes with driver and passenger side switches. Simple install as well. Pull up from the top side of the black plate, unplug and replace the switch module. Install in reverse order.
    Old switches
    New switches
  19. Aug 22, 2022 at 9:12 AM
    #259
    jayb1rd
    jayb1rd ay0 jay
    Monrovia
    2007 PreRunner Radiant Red
    AlphaRexx Headlights | Alpine Touch Screen Double Din | 21' OR Suspension Upgrade
    Any idea if they make these for 05-011 Models?
  20. Aug 22, 2022 at 6:00 PM
    #260
    alvinfromhawaii
    Northern California
    Sorry, supposedly they don’t make for those years.
