I am new. Help me pick out a truck!
Discussion in '1st Gen. Tacomas (1995-2004)' started by mad dog tannen, Oct 5, 2010.
  1. Oct 5, 2010 at 7:54 AM
    mad dog tannen
    mad dog tannen [OP] Member
    Marty
    Jersey
    I am new to Tacomas and and pickups in general but I have friends that love them and I know they last forever. So I decided to get one now that I have a motorcycle to haul around and I love to offroad. Do not be fooled though I am a car nut and I have had a couple Broncos and Jeeps.
    I just want to know what specific things I need to look at when inspecting a Tacoma/pickup. I am looking at early to mid 90's models.
    What frequently breaks?
    Where are common rust areas?
    What are the weak points in the engine/drive train.
    Any help would be appreciated I am kinda shooting in the dark right now.
    ...Thanks in advance!
  2. Oct 5, 2010 at 7:56 AM
    mad dog tannen
    Marty
    Jersey
  3. Oct 5, 2010 at 9:04 AM
    mad dog tannen
    Marty
    Jersey
    Also what are the best engines for the early 90's ?
  4. Oct 5, 2010 at 9:13 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
  5. Oct 5, 2010 at 10:53 AM
    Madjik_Man
    Colorado Front Range
  6. Oct 5, 2010 at 11:06 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Those are Toyota Pickups you are looking at. Not tacoma's.....
  7. Oct 5, 2010 at 6:45 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Stay AWAY from the the pre-1995.5 V6 engines (3.0L). They are terrible.
  8. Oct 5, 2010 at 7:34 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Yes the 3.0 V6 has terrible head gasket issues... and the frames tend to rust out at a ridiculously fast rate, especially in the rear around the leaf springs. The bed itself also rusts bad on older models (I looked at an '85 that had daylight showing through most of the bed and frame.) Other than that, they're pretty much bullet proof. The 22RE will go through 10 frames rusting out before it thinks about quitting.
  9. Oct 5, 2010 at 9:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you ignore the rust issues in the beds, the story goes that the '85 model Toyota pickup was the perfect truck. That was the final year for a straight axle front end and the first year of fuel injection. From a wheelin perspective, the perfect combination.
    If I was looking for a truck of this era I would look for one with a 22r or 22re 4 cyl. As mentioned, the 3.0L v6 was unworthy of Toyota.
  10. Oct 5, 2010 at 11:37 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Yes and it will be pretty much indestructable as long as you change your oil regularly, otherwise the timing chain guides will wear out and the chain will eventually break and cause engine damage.
