I am not a mechanic by all means! Engine swap
Discussion in 'Technical Chat' started by newlifeofriley, Oct 16, 2024.
  1. Oct 16, 2024 at 7:04 AM
    newlifeofriley
    newlifeofriley [OP] New Member
    Tony
    05 Tacoma manual 2 wheel drive 2.7
    I have an 05 Tacoma automatic two-wheel drive with a bad motor. I have an opportunity to get a 3.3 Auto out of a Solara for virtually nothing. Don't know anything about either motor but wondering if I can swap those? and how big a deal it would be?
  2. Oct 16, 2024 at 7:17 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    No.
    A very big deal, even for a straight replacement swap (especially for a self-proclaimed "not a mechanic").
    What happened to your motor, out of curiosity? This is the first 2.7 failure I've ever heard of.
  3. Oct 16, 2024 at 7:24 AM
    newlifeofriley
    Tony
    Ran without coolant , burnt rings and who knows what else. Compression tested around 60 but does still turn over.
  4. Oct 16, 2024 at 7:42 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Non complex motor swap days are long gone. Even if you live in a free state. (Biannual Smog test). Computors, programming, harnesses, ecms, smog systems
    Cut your teeth on pulling the 2.7 and tear it down to a short block and repair. About as basic as they come
    Schlappesepple likes this.
  5. Oct 16, 2024 at 7:57 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    That's a great idea. Am I correct in thinking that with the basic cast iron block, that motor would be conducive to head machining and resurfacing the cylinder walls if needed?
    I don't know the technical term, but I'm imagining something beyond just honing them for new rings. (Or maybe that's all that's required).
    This would be a great project if you have a second vehicle and a mechanic friend (or a good local mechanic).
  6. Oct 16, 2024 at 8:42 AM
    newlifeofriley
    Tony
    Repair was the original plan but came across the 3.3 for trading out a little work so I thought I'd check my options. Thanks for the advise. I'll be back with plenty of questions once I start the repair im quit sure.
