I am not sure if....
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04LTtacoma, Sep 19, 2011.
  1. Sep 19, 2011 at 6:52 PM
    04LTtacoma
    04LTtacoma [OP] Well-Known Member
    Morty
    Outer Space
    my tires are breaking loose or if my clutch is slipping.
    A couple weeks ago I had Toyota replace my clutch. I didn't use a stock clutch instead a marlin crawler 1200HD clutch.
    I have noticed when I shift from 2nd to 3rd or from 3rd to 4th at 3500 rps it feels like the tires brake loose. Immediately after I shift and apply gas my truck doesn't go for a few seconds. It feels like the tires brake loose, but then again i don't hear or see the tires screeching. Maybe the clutch is slipping? This is all done on dry pavement as well.
    When it's wet outside I can brake loose the tires very easily. A few times I was gradually climbing a hill that was wet and my rear tires broke loose... I wasn't pressing the gas pedal aggressively... Any thoughts? Thanks
    EDIT: This happens when I am stomping on the gas before and after I shift.
  2. Sep 19, 2011 at 6:59 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    If you're are shifting at 3500 it could be breaking loose. But the only way to know for sure is if you have a friend drive next to you and look.
  3. Sep 19, 2011 at 7:10 PM
    04LTtacoma
    Morty
    Outer Space
    idk... I adjusted the mirror on the truck to see if I could see the tires. It's kinda hard to tell when you are driving...
    EDIT: Anyone else
  4. Sep 19, 2011 at 8:34 PM
    04LTtacoma
    Morty
    Outer Space
  5. Sep 19, 2011 at 8:44 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    if you're gassing it normally, you shouldn't lose traction. i suspect it's slipping.
  6. Sep 19, 2011 at 8:49 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    It's all the HP your stickers give you all over your doors
  7. Sep 19, 2011 at 8:50 PM
    KalamaKid
    Better get that shit fixed before Friday.
  8. Sep 19, 2011 at 8:51 PM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    Are we talking about like driving down a paved road in high gear at normal driving speeds? Or very low speed crawling shifting from 2nd to 3rd and 3rd to 4th? Unless you have a big block in you taco, there's no way you're spinning tires on asphalt going over 30 mph, lol. Did you follow the break in period on the new clutch?
  9. Sep 19, 2011 at 9:07 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    i can do that on my auto tran j/k, only if tires are wet but yea have u check to see if the rpm revs up when u feel the slip? why would u go with an aftermarket clutch ? the stock can hold more than enough.
  10. Sep 19, 2011 at 9:08 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    very true. it's slipping, take it back asap.
  11. Sep 19, 2011 at 11:20 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea clutch problems. I can spin my tire(s) but only cuz i have an open diff and take a corner fast and floor it...but thats it.
  12. Sep 20, 2011 at 6:53 AM
    04LTtacoma
    Morty
    Outer Space
    Okay, thanks guys.
    Hopefully toyota can fix it before friday, Jason.
  13. Sep 20, 2011 at 6:14 PM
    04LTtacoma
    Morty
    Outer Space
    Or what Jason?! Huh huh?!:p
    EDIT: Relax got it taken care of.
  14. Sep 20, 2011 at 6:24 PM
    96toytaco
    96toytaco Active Member
    96 Tacoma reg cab
    off set rims and tires, everything else is original.
    yeah I tried chirping it from 2nd to 3rd and I can't... sometimes I even chirp without meaning to into 1st and 2nd
  15. Oct 14, 2011 at 8:37 AM
    04LTtacoma
    Morty
    Outer Space
    I am having the same problem as this guy http://board.marlincrawler.com/index.php?topic=55025.0
    Toyota doesn't see my clutch not slipping if they replace the clutch slave cylinder. They're going to take it on a test drive to see what is up. If it's the clutch disc they won't be able to replace it under warranty. Do any of you have the marlin crawler 1200HD clutch kit? Did you ever have the same problem as I am?
