I am REALLY Needing Some help With Vacuum Lines
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Dec 8, 2009.
  1. Dec 8, 2009 at 8:38 PM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Ok, I got home from work about 8:30 and some parts had came today... So I took a couple hours to work on the Taco. :D
    I am puzzled over some of the vacuum lines to the Charcoal Canister and Vacuum Canister (in driver fender well). I took pics to the best of my ability... My cab and wiring is 97 Tacoma Base model, the Charcoal Canister is 98-00. The harness has 2 plugs that were factory taped under the fuse box, so I know they were never hooked up to the (what appears to be) Vacuum Solenoids. The Vacuum canister in the driver fenderwell has the hoe that comes up into the engine bay and goes into these... But there is open ports o nthe top of both of them, and i have no idea where they go... I am missing that part, or these just dont need to be hooked up on my truck. I am doubting I even need them since the harness was taped under the fuse box, and obviously never plugged in before.
    I ran all the wiring through the fire wall, hooked it up... ran all the headlight harness, mounted the fuse box, mounted the Charcoal Canister, and now just trying to figure out where the rest of the hoses go... Here are the pics I have... If ANYONE would please be willing to take pics of their CC and Vac lines to help me I would greatly appreciate it... Like I said, I am not sure what I need hooked up and what I don't.. .
    the 3 hoses my fingers are on are the ones I am stumped on.
    Do these even go on my truck? Where do the open ports(hoses) plug to?
    WTF is this lil guy???
    progress maybe???
    Any help/pics would be appreciated more than I can explain... :D
  2. Dec 8, 2009 at 8:43 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    OK, I know one comes from the air box, across the radiator fan shroud and plugs in to the Charcoal canister... not sure which port it plugs to since its in the bed of the truck... :D
  3. Dec 8, 2009 at 9:28 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Here are the best pics I have at my disposal right now.
  4. Dec 8, 2009 at 9:42 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    The solenoids in the second pic are for the front diff actuator. There should be a couple of vacuum hoses, attached to a metal line that comes up from the diff.
  5. Dec 9, 2009 at 2:40 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    ahhhhh.... so since I have lock in lock out hubs I would not need those... Right?
  6. Dec 9, 2009 at 5:44 AM
    kevhogaz
    SR5 PreRunner
    As long as your front diff is ADD free, the solenoids are useless.
  7. Dec 9, 2009 at 6:01 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    What about this piece???
    What about that blue hose going over the intake pipe??? WHere does the blue part loop back into?
  8. Dec 9, 2009 at 6:20 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Thats a check valve.
  9. Dec 9, 2009 at 8:23 AM
    dually
    dually Low and slow
    That was when the truck was stock, but it hooked up to the intake pipe, then back to the throttle body. Had no idea what it was for.
  10. Dec 9, 2009 at 9:43 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Damn dude I'm lost, i think you need a smog mechanic....:cool:
  11. Dec 9, 2009 at 10:01 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    ^No way... just some detailed pics of where the lines go... :D Like the line with the blue check valve... where does it go to????
