I am really trying to like my new Tacoma....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bbottom, Aug 24, 2021.
  1. Aug 31, 2021 at 3:34 PM
    #281
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Back in the day i bought a used 2 door 1963 327 chevy impala from a friends sister that was given to her by her parents to drive to college that had 60k miles. Best american car ever owned. Years later i bought a used 66 gto with about the same mileage from a private owner that was a state worker i knew nothing about. Boy did i ever get hosed....it was one thing after another for that car. Finally just unloaded it for a 78 toyota wolverine...been buying toyota's since. I can trust them to have world class reliability.
  2. Aug 31, 2021 at 3:37 PM
    #282
    zoo truck
    None
    Its a mac from hell.:annoyed:
    MNMLST[QUOTED] likes this.
  3. Aug 31, 2021 at 3:54 PM
    #283
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
  4. Aug 31, 2021 at 3:58 PM
    #284
    Itchyfeet
    Itchyfeet Well-Known Member
    We read this story a lot. It's always a Corvette and never a 911
  5. Aug 31, 2021 at 4:56 PM
    #285
    Unsunghero
    Unsunghero Well-Known Member
    2021 Metallic Grey TRD Off road
    Ya, and I started watching more reviews and a couple things I noticed
    1. How is a 9 speed transmission only able to get 17mpg city and 19mpg combined? That’s worse than the 6speed Tacoma. Is it the higher truck weight?
    which leads to #2
    2. there were some reviews critical of the engine power. I’m assuming this might be due to a poor factory tune, and/or the extra truck weight. However, there were still more positive than critical reviews regarding engine power
  6. Aug 31, 2021 at 5:24 PM
    #286
    Nodebter
    Nodebter Member
    Jon
    Barcelons Red with a 3/2 Lift
    3/2 Ready lift Cold air intake
    Does anyone know a OV Tuner in East texas? I am ready fed up with shifting issues on my 2019 Taco
  7. Aug 31, 2021 at 5:27 PM
    #287
    Unsunghero
  8. Aug 31, 2021 at 6:48 PM
    #288
    TWTaco
    TWTaco Well-Known Member
    Dave
    We have tuners in Dallas ,Waco and San Antonio.
    KDMax Tuning Group - Google My Maps
  9. Sep 16, 2021 at 2:41 AM
    #289
    electricdgm
    electricdgm Well-Known Member
    Doug
    Florida
    2019 Cement TRD XSP Sport 4x4
    No issues other than recalls, I drive an explorer for work and it's terrible. The transmission and the engine are quirky and I hate the stop/ start engine feature. Just saying none of them are perfect and all the pollution crap does not help.
  10. Sep 16, 2021 at 5:29 AM
    #290
    zoo truck
    None
    Your truck must be not performing like it should. I can put mine on cruise control at 75 mph in 6th and it holds fine...just as my 2001 tundra did in 4th.
  11. Sep 16, 2021 at 5:30 AM
    #291
    su.b.rat
    su.b.rat broken truck
    easily fixed if you want
  12. Sep 16, 2021 at 7:22 AM
    #292
    Jes
    Jes Well-Known Member
    Knoxville
    2017 Taco TRD Pro Cement
    Is this a joke...?
    You are driving a brick 80-90mph and expect it to hold the highest gear and get good mpg?
    doublethebass likes this.
  13. Sep 16, 2021 at 7:34 AM
    #293
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    I drive Phx/LA. Your right, the Tacoma doesn’t like 80. The engine struggles and gas mileage suffers. Of course it’ll do it, but the truck’s sweet spot is 70.
    I also agree the stock seating position sucks. It’s not truck-like at all. Way too low and laid back. That ain’t a truck. Got Seat Jackers front AND rear and damn near raised the electric seat up and forward as far as it would go. Much better.
    I think you need a full-sized truck for your own well being and happiness.
  14. Sep 16, 2021 at 7:56 AM
    #294
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    That's because it's not manual mode. When you put it in "S" mode, it doesn't lock it into that gear, it only lets it shift up to that gear. So if you put it in S1, it keeps you in first gear. If you put it in S2, it only shifts from 1st to second. If you put it in S6, you may as well keep it in drive.
  15. Sep 16, 2021 at 8:26 AM
    #295
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Found the issue.
    doublethebass and cryptolyme like this.
  16. Sep 16, 2021 at 8:45 AM
    #296
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    s6 is useless unless you are cruising on flat highway. also it's pretty much the same thing as leaving it in "D". get some seat jackers. that fixes the seat angle.
    Casswick[QUOTED] likes this.
  17. Sep 16, 2021 at 9:41 AM
    #297
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    I just read the first couple of pages and now I'm here. What did you end up doing about the truck?
  18. Sep 16, 2021 at 10:55 AM
    #298
    ret42
    VA
    I believe what you are looking for is a manual transmission. There are exceptions out there, but this is how automatic transmissions have always worked. It's no different than if you were to drop your 1st gen Tacoma from Drive down to 3.
  19. Sep 16, 2021 at 12:07 PM
    #299
    zoo truck
    None
    On my truck there is no S6. You can put it in any S mode up to S5, and it will hold the gear till a certain rpm is reached and it will automatically upshift to the next gear if those rpm are exceeded....same for using S mode gears like 1st thru 4th when going down a steep grade. It basically will force you to use the brakes if the engine is too wound up. Imo, i think toyota did this to protect the engine from extended periods of excessive rpm.
  20. Sep 16, 2021 at 12:31 PM
    #300
    cryptolyme
    Virginia
    weird. i'm 6'3" and i still have 2-3 inches of headroom
