I am starting to get condensation in headlight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobbyds1, Oct 10, 2023.
  1. Oct 10, 2023 at 9:42 AM
    bobbyds1
    bobbyds1 [OP] Well-Known Member
    Bob
    2013 tacoma base
    I recently deglazed my head lights and put new led bulbs in I had to cut the rubber covers a little now i Notice in the morning there is condensation in one of my headlamps any suggestions how this can be happening and how to resolve with out having to buy replacements.
    Thanks in advance
  2. Oct 10, 2023 at 10:01 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    open up that rubber and reseal them
    i ended up drilling a hole in bottom so they drain out
  3. Oct 10, 2023 at 11:26 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You cut the rubber covers, now water can get in
    FYI those LED bulbs are obnoxious to oncoming drivers. They don't belong in halogen housings
    Taco 422, Strictlytoyz, 23MGM and 3 others like this.
  4. Oct 10, 2023 at 11:35 AM
    Waasheem
    Waasheem
    2007 xrunner
    THIS!
    Taco 422, 2015WhiteOR and knottyrope like this.
  5. Oct 10, 2023 at 7:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    X2….
    I agree
    Taco 422 and 2015WhiteOR like this.
  6. Oct 10, 2023 at 8:36 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
  7. Oct 10, 2023 at 8:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You could just live with the condensation :notsure: Hell, the $1000 aftermarket quad-projector LED headlights on eBay all have vent caps (i.e. they're vented to atmosphere to equalize pressure).
  8. Oct 10, 2023 at 11:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You literally cut the seals designed to keep the moisture out and as a result of you cutting the water proofing seals, you now have water intrusion. LEDs definitely do not belong in the halogen headlights, whatever company sold you that was more interested in your money than selling you something that actually works.
    This thread has everything you need for 2nd Gen headlights, and doesn't cause condensation in your lamps while being substantially higher performing than any PnP LED product could ever achieve.
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    ace96 and Taco 422 like this.
  9. Oct 11, 2023 at 4:30 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    What you have inadvertently discovered is that your headlights are a collection of individual parts that are designed to work together as a system. Mess with one or more parts of that system and you risk compromising the performance of the entire system.
    The rubber boot that you had to cut / modify is the main waterproofing element of the OEM Tacoma headlight using 9003 bulbs. Other bulb types (used by other manufacturers) utilize a twist / lock style bulb base that incorporates an O-ring to seal the bulb. Cutting the seal was probably only part of your problem though. Many drop in LED bulbs are made by (mostly) Chinese manufacturers who know little about lighting and the true functions of the parts of a modern headlight housing. Because of this, many of them don't fit very well in the housing which leaves room for water to get in. Couple that with your modified seal and you have a recipe for water intrusion.
    As others have already said, getting rid of the LED bulbs - and replacing the rubber seals - should solve the problem of more water getting in. You'll also make oncoming drivers much happier in the process. And then there's the problem of getting the moisture that's already in your headlights out ...
    crashnburn80 and 2015WhiteOR like this.
  10. Oct 12, 2023 at 4:46 AM
    bobbyds1
    Bob
    2013 tacoma base
    I replace the rubber covers and can get the moisture out but in the morning there is moisture in it again but it only happens with one headlight not both.
  11. Oct 12, 2023 at 8:46 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    The same thing -- condensation inside the headlamp housing in the mornings and water intrusion during a rainstorm, top outside on driver side -- started on my 2015 Tacoma the other day (running stock H4s and no mods). I was planning to refinish the headlamps prior to this, as they were starting to get hazy. But with a break in the seal, it made my decision easy.
    New OEM headlamps on both sides going in now.
    I have a set of LED H4s with warm-white 3000K emitters that I'm going to try to shoehorn into the light buckets on my 1962 Triumph TR3B. Taking a lotta amps off the original generator (pre-alternator) will help its driveabilty, and it gets so rarely driven at night (probably 50 miles a year or fewer) that the higher glare truly won't be a significant issue. But as an experiment, I put one of those LEDs in the Tacoma alongside the original H4 and the glare from the LED was obvious just standing in my driveway. Had I been lower and farther downstream it would have been even worse, no doubt. Don't put those LED headlights in place of original halogens -- listen to the sound advice of everyone who's advising against that!
  12. Oct 13, 2023 at 6:57 AM
    771Doug
    771Doug Well-Known Member
    Virginia Beach, VA
    '08 V6 Pre-Runner
    I get that on the passenger side light from time to time. I just pull the bulb out of the housing for a few hours until the condensation dries up.
