I bought a 2003 tacoma REG CAB 4x4 ?? Why??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tripodchief, Feb 24, 2020.
  1. Feb 25, 2020 at 12:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm glad you looked. I'm glad it's fine, and that you are protecting it already.
    But the factory finish sure isn't powdercoat!
    GQ7227 likes this.
  2. Feb 25, 2020 at 12:51 PM
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    I found the bed to be smaller than my initial thought when fitting a motorcycle in this past week. Either way, it will tower a trailer fine if you can't fit in the bed as the tongue weight is like 350-400 pounds even for 4 cylinder.
    Congrats on purchase, got mine in Late October.
  3. Feb 25, 2020 at 1:18 PM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    So I have (2) 2003 durangos 4.7's one is my wifes and the other is a spare. I have the 04 Taco. I see them / drive them side by side. I am an old Mopar guy . As much as I like Mopars and the Durangos are ok, the Taco in design quality is so much better. I spend 2 to 3x more time maintaining the dingos vs. the taco. and its not just cause there are 2 of them, they simply screw up and parts wear out so much more often.
    Tripodchief[OP] and GQ7227 like this.
  4. Feb 25, 2020 at 3:04 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    Welcome to the club! Suspension wise maybe look for some bilstein 4600’s. Good shocks and not too pricey. They’ll run you around 45$ a shock on Rockauto
    GQ7227 likes this.
  5. Feb 25, 2020 at 3:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Got yourself an awesome little truck there man.
    They go great in the woods. Probably one of the best pieces of hunting equipment I’ve ever owned. Lol
    six5crèéd likes this.
  6. Feb 25, 2020 at 3:09 PM
    J.A.92
    J.A.92 97 Tacoma 4x4 lx 5 speed manual.3.4L
    Juan
    1997 Tacoma 4x4 lx xtra cab.3.4
    Nice!
  7. Feb 25, 2020 at 7:31 PM
    1997tacomav6
    Denver
    Why?
    Because these trucks will keep going and going but they do need maintenance
    J.A.92 and GQ7227 like this.
  8. Feb 25, 2020 at 7:38 PM
    Tripodchief
    Tripodchief [OP] Well-Known Member
    Cb
    2003 tacoma 2.7 regular cab 5 speed 4x4
    None yet
    het CL bill. I wasn't sure about the powdercoat but it looks like powdercoat or something similar on just the frame unless that was how the *new* frames were made.
    didnt Toyota offer a rust proof coating as well?
  9. Feb 25, 2020 at 7:40 PM
    Tripodchief
    Cb
    None yet
    ill take more pictures after I wash her, Im on a private dirt road so its always mud season lol
  10. Feb 25, 2020 at 7:55 PM
    Tripodchief
    Cb
    None yet
    once the weather warms up gonna pull the bed clean up anything that needs it , applying chassis saver magnet paint( unless I come across a better idea), going to drop in a new fuel pump while im under there. I know it has a new rack and front axle, new brake booster and lines . all the manifold bolts have been replaced sooo I think I might upgrade the header and muffler, already has new cat and o2s.
    this weekend will b sparkplugs and throttlebody/aic maintenance
    I also have an appointment to change out tranny and diff oils.
    GQ7227 likes this.
  11. Feb 25, 2020 at 7:59 PM
    Tripodchief
    Cb
    None yet
    I already dropped in a 850 cca battery with new terminals spliced in to run a dual battery sytem with inverter, already have an extra deepcycle just need to pick an inverter up
    frenchee likes this.
  12. Feb 25, 2020 at 8:54 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you could contact the prior owner and see if they paid extra to coat it :notsure:
    or check the carFax, it may indicate that from a dealer service record perhaps
    Black DOG Lila likes this.
  13. Feb 25, 2020 at 9:08 PM
    Tripodchief
    Cb
    None yet
    so I was able to register the truck with Toyota owners dashboard, and I can see all service records and invoices from new to 2016. in 2012 when the frame was replaced they also added the *Toyota frame corrosion-resistant treatment* the fine black coating on the frame ?
    GQ7227 likes this.
  14. Feb 25, 2020 at 9:14 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    my advice would be to take a Halogen light everywhere and check for possible cracks in that stuff, etc. if the salt water can seep behind it just festers like corollavirus
    the halogen light will show the bad things loud and bright
    also, you mention the Mopar stuff, my sister and her husband are Mopar or nothing
    i got my truck the year they were married, i still have my truck running very well and they have probably gone through almost 10 used Mopars during the past 2 decades :( but at least he sorta kinda knows how to fix them, until this Charger they recently got and having some major complicated issues with it
  15. Feb 25, 2020 at 9:32 PM
    #35
    Tripodchief
    Cb
    None yet
    thanks! I try my best to do all my own work and learn as I go. Ive been lucky to have some older friends as neighbors both owned their own garages for a combined 85 years. we generally do everything in the yard unless we need a lift. our friend up the road has a huge shop, and is putting in a lift outside this summer. which will be sweet
  16. Feb 25, 2020 at 9:43 PM
    #36
    GQ7227
    GQ7227 mw survivor
    J A Y
    I would also make sure all the frame drain holes on the bottom were not sprayed over with that stuff and are free and clear to drain properly
  17. Feb 26, 2020 at 9:57 AM
    #37
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Good one Jay:thumbsup:
    :rofl::rofl::rofl:
  18. Feb 26, 2020 at 10:04 AM
    #38
    GQ7227
    GQ7227 mw survivor
    J A Y
    the corollavirus?
    i found it clever as there are currently a dozen or so patients in quarantine with symptoms in a hospital relatively near to me in town
    state of the art facilities we have here i guess for that coronavirus
    they are brought in undercover of the night
    hoping that nobody dies of this thing here!
    also i sport an old corolla that has a virus of sorts
    but the heater still blows so hot!
  19. Feb 26, 2020 at 10:16 AM
    #39
    Black DOG Lila
    Virginia
    How very clever you are indeed:thumbsup:
    Idiots out wandering around calling it Corona virus:rofl::rofl::rofl:
    Hope the quarantine stops the global pandemic :amen:
