I bought a set of BFG K02s
Discussion in '1st Gen. Tacomas (1995-2004)' started by coffeybean, Aug 13, 2023.
  1. Aug 13, 2023 at 1:52 PM
    coffeybean
    coffeybean [OP] Well-Known Member
    Clarkston WA
    2003 Tacoma 2.7L 5 speed
    Tundra Front disk brakes, Recarro bucket seats, the switchback blinker/running light mod, sound insulation and new speakers. 2023 - New Bilstein 4600s, new center bearing and clutch pack.
    I upgraded my tires before the run up to Alaska and the North Slope Haul Road. During the trip I ran the PSI at 30 in the front and 32 in the rear on "good" roads, on the Haul Road itself (a very not good road) everything was at 20 psi.
    Before it is asked the tire size is 265/70 in 16 inch wheels. Stock snowflakes
    The question is what is a reasonable PSI to run these at since this is my daily driver? I don't often haul stuff and rarely pull a trailer. Should I go with the Toyota recommended pressures of 24 in the front and 27 in the rear or since these are not passenger car tires those values no longer apply?
  2. Aug 13, 2023 at 1:53 PM
    Bishop84
    Bishop84 Well-Known Member
    This page works wonders. I'd probably go 30 front, 30 rear, and 35 rear when loaded.
    Wulf likes this.
  3. Aug 13, 2023 at 2:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What is the load rating on the BFGs?
    Wulf likes this.
  4. Aug 13, 2023 at 2:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Chalk test.
    Nano909 and Red_03Taco like this.
  5. Aug 13, 2023 at 2:17 PM
    coffeybean
    Clarkston WA
  6. Aug 13, 2023 at 2:18 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I run my KO2's 285/78/17 "E" load rated at 25psi truck on road. They have been wearing evenly. If this size was available in a "C" load rating I would run those but they are not. If I was running "C" I would most likely be around 28psi-32psi max. My truck in daily driving config. with myself, 1/2 a tank, the spare (about 90lbs) and maybe 50lbs of gear that includes a bed box is 4900lbs.
  7. Aug 13, 2023 at 2:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It really gets down to what is most important, ride quality or mileage, both fuel and tire wear.
    If ride comfort is a consideration, lower psi is the route to go. The actual amount will depend on your vehicle weight too. A stock, empty 1st gen Tacoma is really too light for an e-rated tire IMO.
    Rusty Taco 11 likes this.
  8. Aug 13, 2023 at 3:03 PM
    coffeybean
    Clarkston WA
    @Digiratus These were purchased for the run up to Alaska and the Haul Road. For the trip I had 2 people, topper, platform in the bed and a full complement of camping equipment with water! I never weighed it fully loaded but I know that "empty" (topper, platform, 2 people and 1/2 tank of gas it weighed in at 4280) At the time I made the purchase I wasn't thinking about weight, I was more concerned about road conditions. These tires probably are overkill for my typical use.
  9. Aug 13, 2023 at 10:19 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I'm running BFG KO2 in 31X10.5X15 in load range C at 25psi front and 24psi rear measured when hot.
    Verified with chalk test when first installed. After 20k miles, the wear is even across the face.
    4X4 Double cab with the 5VZ 3.4L
    YMMV
    Fish 2000 likes this.
  10. Aug 14, 2023 at 8:27 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I run my KO2's (265/75r16, load range E) at 29/27 psi (front/rear), verified by the chalk test, with an empty truck (no armor or other significant extra weight to speak of).
    Tire shops always like to inflate them to 32-33 psi after rotations, and the truck feels more comfortable at 29/27
  11. Aug 14, 2023 at 5:34 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
