I bought one...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Effenglide, Feb 16, 2015.
  1. Feb 17, 2015 at 7:23 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    What he said^^^
    You're broke now.
  2. Feb 17, 2015 at 9:46 AM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    :threadjacked: lol
    Make sure you don't have an auto limited slip differential I think there's an additive or different fluid you need to add.
    The Transmission I just bought the Toyota WS ATF fluid. I can't remember if it was synthetic or not. All Transmissions and Differentials that I've worked on have a fill plug, overflow plug and a drain plug. So instead of a dip stick you fill up fluid till it comes out of the overflow hole.
    I followed this for the transmission http://www.tacomaworld.com/forum/2nd-gen-tacomas/68462-diy-full-flush-automatic-transmission.html
    I found this one too.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/63851-how-drain-refill-automatic-transmission.html
    I still got to look into the power steering. I might do just a flush today with the turkey baster method. (Suck out the old fill up with new fluid.) and engine oil change unless my muffler gets here then I'm going to fire up my Lincoln Electric welder :D. Then I'm going to burn that in the stock muffler's location lol. I just recently found out the stock TRD exhaust are mandrel bends! So if I did a drop in muffler it's basically the same as a full cat back system.
    I'm not an expert mechanic, but I like to wrench on anything lol. Luckily here their are plenty of helpful people with knowledge and tutorials for most things on our Tacomas.
  3. Feb 17, 2015 at 10:32 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Check the NHSTA site for recalls on it unless you know they've been done. They have a nifty feature now where you can put in the Vin and it will tell you if the recalls for your particular truck have been done or not.
