I bought the TRD Pro/SEMA Replica Wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustinuhls, May 10, 2020.
  1. May 10, 2020 at 5:50 PM
    dustinuhls
    dustinuhls [OP] Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    To each their own! In my opinion, 20s just don't look right on the Tacoma. Doesn't matter if it's 1st, 2nd, or 3rd Gen... Change my mind.
  2. May 10, 2020 at 9:40 PM
    TRDSport10
    TRDSport10 Well-Known Member
    Rhode Island & Virginia
    '10 AC TRD Sport 4x4 - Silver
    TRD Exhaust, Tube Steps, Towing Hitch, Paint Protection Film, Bed Mat, Wheel Locks, Spare Tire Lock, First Aid Kit, Ashtray Cup, TRD Air Filter, TRD Oil Cap, TRD Radiator Cap, FJ TRD Hub Caps, FJ TRD Shift Knob, BackFlip F1, TSB Rear Springs, Coupe TRD Battery Hold Down Bar, KatzKin Leather Seats with W.E.T. Seat Heaters, WeatherTech: FloorLiners DigitalFit, Side Window Deflectors, ClearCover License, LampGard
    Dustin,
    Envy – Envy! Super nice choice in wheels - like your 8" choice. Gunmetal color wheels brightens visual appearance of your Taco IMHO. Go ahead and doll-up the caps, - easy enough to do - or redo. As you see by my profile photo, FJ caps did it for me.
    Enjoy, drive it like you stole it!
    dustinuhls[OP] likes this.
  3. May 10, 2020 at 10:43 PM
    dustinuhls
    Manhattan, KS
    2015 TRD Sport 4wd
    So, I just did the emblems in gunmetal Plasti Dip to try to pull the whole look together. I did 5 coats of gunmetal and 2 coats of clear gloss. Turned out pretty sweet! At least I think so. What do you think? Better than chrome?
    It almost looks black in the second photo, but it totally looks gunmetal in person. Matches the wheels perfectly.
    TRDSport10 likes this.
  4. May 11, 2020 at 1:53 AM
    TacoTuesday1
    FL
    They don't come with TRD center caps?
    good to know the 265 70 17 can stretch from 17x7.5 to 17x8
    not sure why I always thought the OEM 5-spoke 17's were 17x8.
    Am not sure what dimensions are better or why.
    On street cars wider wheels usually means better grip in flat turns,
    IDK if Toyota designed it narrow to take up less room on a trail without hitting anything
    I wonder how hard it was for the shop re-mounting the tires to swap over TPMS
    Costco Tire Center has a stock of TPMS service kits, and Toyota probably does too, but not every shop probably.
    (plastic bag with new crush washer, rubber gasket, valve core, etc.)
    looks like an X-runner
  5. May 11, 2020 at 7:45 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I think the color of the wheels looks perfect against the color of your truck. Small details like matching the emblems only helps tie things in even further.
    TRDSport10 and dustinuhls[OP] like this.
  6. May 11, 2020 at 8:33 AM
    dustinuhls
    Manhattan, KS
    2015 TRD Sport 4wd
    They don't come with TRD center caps because that's trademarked by Toyota. There's several places online that sell the center cap decals. I'm just trying to decide which color to order.
    I'm sure Toyota has to do the narrower wheel size to comply with regulations that the wheels must be covered by the fenders. They couldn't stick out from the factory.
  7. May 16, 2021 at 8:21 PM
    Bammer55
    Bammer55 Active Member
    Are you sure yours were +15mm offset? The ones their listing now say 17x8 +5mm offset.
  8. Jan 14, 2022 at 6:43 AM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
    i like that not the same old thing
    Too Stroked[QUOTED] likes this.
  9. Jan 14, 2022 at 9:53 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    aside from the blank center cap, i couldnt tell the difference. looks good
  10. Jan 14, 2022 at 10:05 AM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    thanks for these pics. the poke on those wheels is almost the same (1.7mm) as the sema/4runner wheels. looks great. that's exactly how far i wanted my wheels to stick out
  11. Oct 23, 2024 at 6:17 AM
    Swywell
    Swywell Member
    Sorry for bumping old thread--was curious, OP, if you were still happy with these wheels and they have held up OK since your post? Also are you running a 2in front level, or bilstein lift? It's hard to tell from the camera angle.
  12. Jan 31, 2025 at 4:24 PM
    pvanzee82
    pvanzee82 Well-Known Member
    Pete
    Iowa
    2022 TRD Sport 4WD BCM
    Same here. Also, do you know the load capacity per wheel. I just bought replicas and the load capacity is 1686 lbs per wheel which seem low for truck wheels. The OEM wheels of that design have a 2100 lb load capacity
