I broke a clip
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoguy, Oct 18, 2009.
  1. Oct 18, 2009 at 4:41 PM
    Tacoguy
    Tacoguy [OP] Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    After noticing my MPG's dropping quite a bit lately, I decided to check the spark plugs.
    I did change them only 8k miles ago, but I also only put in NGK Iridium single ground, which I guess was a bad decission.
    However once trying to get the spark plugs out of the passenger side, I broke the clip off of the one wire that attaches to the boxy thing (Yes, I know little about cars) :eek:
    Now instead of being fit securely, the wire is a bit loose. What exactly is it, and should I replace it?
  2. Oct 18, 2009 at 4:47 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    Do you mean the plug wires? Buy a new set.
  3. Oct 18, 2009 at 4:48 PM
    Tacoguy
    Alex
    Chicago
  4. Oct 18, 2009 at 5:07 PM
    Tacoguy
    Alex
    Chicago
    Do you think that it is ok to run the truck with a broken clip on the ignition coil connector?
    I dont imagine that the connecter is something that can be changed by itself. I will probably have to replace the whole thing. :confused:
  5. Oct 18, 2009 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    98tacoma27 said it best....Replace the wire.
  6. Oct 18, 2009 at 5:25 PM
    Tacoguy
    Alex
    Chicago
    Can you just replace the ignition coil connector for one coil? Or do you have to replace them all?
  7. Oct 18, 2009 at 5:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is it the coil or wire that has the broken connector?
  8. Oct 18, 2009 at 5:40 PM
    Tacoguy
    Alex
    Chicago
    its the coil connector, the one that connects to the ignition coil.
    The clip that keeps it in place broke off and now it is loose.
    I am thinking that a temporary fix would be to just to tape it in place.
  9. Oct 18, 2009 at 5:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can do that. Be prepared to replace it though. :)
  10. Oct 18, 2009 at 6:00 PM
    Tacoguy
    Alex
    Chicago
    But do you think that I can just replace the one connector? Or will I have to replace the whole thing?
  11. Oct 18, 2009 at 7:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I imagine the whole coil.
  12. Oct 18, 2009 at 7:45 PM
    Tacoguy
    Alex
    Chicago
    Well I just used some electrical tape to tape it up and it is quite secure now.
  13. Oct 19, 2009 at 7:40 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Use a tywrap. Tape will eventually come off.
    As long as all the wires are connected and connected securely, you should be fine.
  14. Oct 19, 2009 at 11:49 AM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
    I did the same thing with the High Tension Cord. I used 2 Zip ties holding it in place. Been there for over 3 yrs.
