I can’t tell if my 2022 SR has the tow package.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Uplandhunter95, Sep 14, 2024.
  1. Sep 14, 2024 at 1:06 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Well ... we cannot ignore the contributions of @daveeasa and @Puppypunter. Shame on you! :boink:
    Stuck in VT[QUOTED] likes this.
  2. Sep 14, 2024 at 1:10 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    that is an OE tow package hitch, there was no external trans cooler on your year, like mentioned, look for the OE 7 pin connector on the bumper
  3. Sep 14, 2024 at 1:18 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm not sure about newer trucks, but those with tow package are rated at 6400-6500 lbs towing. The ones without tow packages can still tow, but are limited to 5000 lbs.
    But that is how much they are rated to PULL. You also have to consider how much weight the suspension is rated for and that is based on your payload rating. Which is different for every truck, you'll just have to check the sticker on the driver's door jamb. MOST 3rd gen 4x4 crew cab Tacoma's will be rated between 900-1100 lb. A 2wd and/or access cab will be a little higher. That is the limiting factor and very few Tacoma's can realistically tow much over 4500-5000 lbs even with the tow package.
    If you have the 7 pin connector you're good for at least 5000 lbs. If the GVWR of the trailer is 3000+ you also need trailer brakes and you may need to install a brake controller if it doesn't have one from the factory. Not expensive nor hard to do.
  4. Sep 14, 2024 at 1:44 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Before this thread goes off the rails with well intended yet inaccurate information. Here are some specs from a Toyota dealer. In 2022 if it's a v6 it is rated at about 6500lbs and if it's a I4 its rated at 3500lbs. The "tow package" doesn't have any meaning post some year prior to 2022. I remember it having meaning in 2016 when I bought my SR5, but not when I bought my 2020 OR.
    https://www.performancetoyotastore.com/blog/toyota-tacoma-towing-capacity/#:~:text=The towing capacity of the 2022 Toyota Tacoma ranges from,look at its exact configuration.
  5. Sep 14, 2024 at 3:01 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    where did you read about a external mini transmission cooler?
    Chew likes this.
  6. Sep 14, 2024 at 3:34 PM
    Koolbreeze7
    Jon
    Jersey
    I was insinuating that whatever it is, if it has the factory pieces it is the "tow package" for that year. No one in their right mind would add those factory pieces, the OE bar, OE 7 pin for what they are worth from the dealer
  7. Sep 15, 2024 at 10:19 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    I appreciate it, but the only reason I can do what is do is because of @caribe makaira :bowdown:
    Stuck in VT and RustyGreen like this.
  8. Sep 15, 2024 at 12:06 PM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    I have the tow package...but was told it needed a brake controller installed in order for it to work correctly..
  9. Sep 15, 2024 at 12:19 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Some don’t have the 130-amp alternators either - when I was shopping for mine in ‘17, one dealer showed me one with a “tow package” and it had those OEM plugs on it, but then upon inspecting it some more for what else was installed, I could see that the receptacle was the only thing they added, there was no external transmission cooler (like the real tow packages being sold back then) and it had just a 100-amp alternator. I don’t know if it had a trailer brake connector, I didn’t look for it back then. I ended up going to a different dealer and got the real thing instead for the same upgrade price.
    See Carbie’s post earlier for the plug you need, it’s easy to install the controller if you want to do it yourself.
  10. Sep 15, 2024 at 4:36 PM
    caribe makaira
    Caribbean, Puerto Rico
    :anonymous::hattip:
  11. Sep 15, 2024 at 8:03 PM
    RichochetRabbit
    We are a "mutual admiration society" indeed, @Puppypunter.
    Puppypunter likes this.
