I can now see Taco lean from inside the truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tehkoema, Sep 27, 2020.
  1. Sep 27, 2020 at 8:37 AM
    Tehkoema
    Tehkoema [OP] Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    This is starting to bother me. Whats the easiest, most reliable way of addressing this?
    Please dont suggest 5100s or anything too pricey.
    Gunshot-6A likes this.
  2. Sep 27, 2020 at 8:41 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    5100s are like the cheapest good option, my guy. Or find shocks and leaf packs from someone upgrading to better stuff and refresh your OEM setup.
    A patch thatll get you by would be a 1/4" spacer on the front driver side.
  3. Sep 27, 2020 at 8:42 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Ignore it.
    It's your mind making a big something out of a little nothing.
    drewmac270, Boghog1, tonered and 23 others like this.
  4. Sep 27, 2020 at 8:46 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This, life is too short for me to hung up on trivial things
    tonered, Rick111, whatstcp and 3 others like this.
  5. Sep 27, 2020 at 8:46 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    200 pounds of bagged drainage stone, passenger side. $25 fix.
  6. Sep 27, 2020 at 8:49 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    he could lose weight
    Tacoman97, Rick111, JasonLee and 8 others like this.
  7. Sep 27, 2020 at 9:12 AM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    Liposuction isn't cheap or easy guys, c'mon with these solutions.
    Upgrading the whole suspension for a lean doesnt seem worth it.
    Idk why but it just rubs me the wrong way, need to stop looking I guess. Do 4Runners have this issue too?
  8. Sep 27, 2020 at 9:14 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I couldn't even tell, to be honest. Especially since the rear of most cars, such as the one pictured, is higher.
    DWD484 and Tullie D[QUOTED] like this.
  9. Sep 27, 2020 at 9:19 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    This.
    Don't use other objects as reference, as you don't know if you're squared up with the perspective, and you especially don't know if they're level.
    If you really must know, a carpenters level against front bedrail will tell you. But also this is one of those situations where the phrase "ignorance is bliss" definitely applies.
    MR E30, tonered, Rick111 and 5 others like this.
  10. Sep 27, 2020 at 9:30 AM
    RedWings44
    Michigan
    Every vehicle I've ever owned has done it to a degree. Ford, GMC, etc. You just only seem to notice it on your own vehicle. Not entirely sure why it is called the "taco lean."
    JNG, tonered, davidstacoma and 2 others like this.
  11. Sep 27, 2020 at 9:31 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Will warranty cover it ??
    t0nyvalenzuela likes this.
  12. Sep 27, 2020 at 9:45 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Measure frame to ground both side I'll bet you will find them to be the same the rest of it is perception.
    Rick111 likes this.
  13. Sep 27, 2020 at 9:46 AM
    canyonchaser
    canyonchaser Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    the simplest solution to mitigate this. Whenever you put something in the back of your truck, put it on the right side to counteract the weight of the gas tank on the left. On my Gen II, I've done this since day one and I have virtually no lean.
  14. Sep 27, 2020 at 9:47 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Cheapest route is just forget about it. Battery, You, Fuel tank on the same side.
    Rick111, b_r_o, Chew and 1 other person like this.
  15. Sep 27, 2020 at 9:51 AM
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
  16. Sep 27, 2020 at 10:25 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Theres no lean at all on mine i can see, only the rear of the truck looks about an 3/4 to an 1'' higher in the rear.
    Rick111 and Tullie D[QUOTED] like this.
  17. Sep 27, 2020 at 11:56 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    So you are very careful to make sure the tank is always full of 120# of fuel and factor in the proximity of the right side of the tank being close to center and the tank itself being supported more so by the rear axle. Mine is sitting in my garage with about 19 gallons of fuel (something close to 114 lbs of fuel) in 18 miles it's going to be about 6# lighter. The frame measured at both front cab mounts is spot on 13" +/- maybe 1/32 or about 3/100" my eyes are not that good. I would suggest measuring body parts on a flat floor and see what you get side to side. There is a discrepancy but it is not that much considering how long the truck is. Left side rear fender at the wheel arch is 1/2" lower than the right the center of the left head light is a 1/2 higher than the right go figure. You got to have a pretty good lean to visually see it time to get out your lazar. Worry less drive more.
    tonered, Tullie D and hiPSI like this.
  18. Sep 27, 2020 at 12:04 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Every vehicle has this issue. No vehicle is never completely perfectly level.
    Why? Tire air pressure, worn components, uneven ground, full fuel tank, big ol fat wife, etc.
    Yes 4Runners too. Ford trucks too. My wife's CRV. My Tundra.
    Unless you buy a vehicle with a computer controlled suspension they will always be unlevel depending on the factors listed above. Now if it were obvious, like a two inch difference, then it's no big deal.
    drewmac270, tonered and Chew like this.
  19. Sep 27, 2020 at 12:50 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I have visible taco lean so I made the radio louder.
  20. Sep 27, 2020 at 12:57 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
