I can only hope for a blown fuse at this point
Discussion in 'Audio & Video' started by tacomatrdod, Apr 9, 2013.
  1. Apr 9, 2013 at 4:52 PM
    tacomatrdod
    tacomatrdod [OP] Well-Known Member
    Mud Country
    2010 tacoma trd offroad
    Toolbox, stereo upgraded a tad
    SOOO i thought it would be a good idea to source power for a daystar rocker switch from the same power my headunit uses, and same ground although the switch has:
    power in, power out, ground.
    so i hookd power in up, no problem light auctually turned on and i hooked up ground to the chassis, then i hooked up power out and flipped the switch and now my headunit wont turn on :/ , any help? Or am i out 150 for a new head unit? :(:(:confused::confused:
  2. Apr 9, 2013 at 5:00 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    You need to use a relay in conjunction with the switch. I am not sure what you did, check everything is wired correct and make sure the fuse on the back of the head unit isn't blown.
  3. Apr 9, 2013 at 6:00 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    There may also be a fuse on the back on head unit you can check as well
  4. Apr 10, 2013 at 5:01 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Audio system fuse is a 30A in slot 11 in the fuse box behind the battery in my 2009. There's a diagram on page 396 of my manual. Assuming yours is the same as mine, it's easy to find.
    What are you trying to switch power to with the switch? Taco Terror is right on when he said you need to control a relay coil with the switch, and route power to whatever you are switching power to using the relay contacts and a different power source.
