I can see cutting the trailer hitch off becoming a thing
Discussion in '4th Gen. Tacomas (2024+)' started by Jacob06, Jun 11, 2024.
  1. Jun 11, 2024 at 2:29 PM
    Jacob06
    Jacob06 [OP] Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    I think you could keep the crossmember, just cut the hitch off and build the new bumper around it or integrate it into it. The back end of this truck is begging for trouble or to be "fixed" for offroad use.
    The pipe,tire, and hitch all need to get recycled.
    To get that bed deeper, they lowered the spare a lot.
    By the time you needed it, it would likely have a hole in it from dragging.
    And if you removed the spare before wheeling, then it's easier to get hung on the hitch.
    They do make hitch skids but that makes the departure angle even worse.
    The hitch has to go somewhere else unless you're only crawling malls
  2. Jun 11, 2024 at 2:30 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Doesn't the trailhunter have an ARB rear bumper stock? What does that do with the hitch?
  3. Jun 11, 2024 at 2:31 PM
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    The ARB bumper is nice but the hitch is in the same spot and doesn't solve the problem.
    BabyBilly[QUOTED] likes this.
  4. Jun 11, 2024 at 2:32 PM
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    It just hangs down like normal. But the TH has a 3 inch lift essentially over the base models.
  5. Jun 11, 2024 at 2:36 PM
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    Lowest point needs to be close to where those Hi lift jack points are or right above the hitch.
  6. Jun 12, 2024 at 1:39 AM
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
    IMG_0614.jpgThe Trailhunter has the exhaust dumps in front of the axle
  7. Jun 12, 2024 at 4:15 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I would not purchase a 4th gen Tacoma with the intentions of offroading where the hitch will contact the ground.
    I agree it's in the way if you are going off road.
  8. Jun 12, 2024 at 4:53 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Its similar to the rear crossmember on the Gx460-470, 4runnner, fj. Some bumper companies cut it out for more options when building the bumper
  9. Jun 12, 2024 at 12:17 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I think your speculation is accurate, since they've done it for every previous gen as well to add clearance.
    My guess is they would just grind/cut away the hitch portion, and a new bumper will have it behind the plate. Would depend how it's constructed though, which I have no idea.
  10. Jun 12, 2024 at 12:20 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    These days they expect you to tow your sxs to the trailhead.
    andrewtheadventurer likes this.
  11. Jun 12, 2024 at 4:53 PM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    Looks like you could cut the hitch box off without affecting the structural strength. Not sure how you would add a hitch back on up higher though.
  12. Jun 12, 2024 at 6:12 PM
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    There is nothing behind the license plate.
  13. Jun 12, 2024 at 6:25 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Jacob06[QUOTED][OP] and TurboDA6 like this.
  14. Jun 12, 2024 at 6:29 PM
    MGMDesertTaco
    That spare doesn't have hardly any tread depth to it. o_O
  15. Jun 12, 2024 at 6:58 PM
    #35
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    The spare is a joke!
  16. Jun 12, 2024 at 7:14 PM
    #36
    batacoma
    batacoma Truck Wars
  17. Jun 12, 2024 at 7:29 PM
    #37
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Be grateful for what you get. The 5th Gen Tacoma will be equipped with a single can of Fix-a-Flat.
  18. Jun 13, 2024 at 5:45 AM
    #38
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Nothing. The ARB replaces the plastic bumper "shell" with steel.
    4Runners and Land Cruisers have been this way for decades. Most bolt-on aftermarket bumpers leave the hitch and crossmember as-is, so departure clearance ends up same as stock. A couple of high-clearance designs require cutting off the crossmember, e.g. https://nguyenworksusa.com/shop/ols/products/5th-gen-4runner-plated-low-rear-bumper
  19. Jun 13, 2024 at 6:37 AM
    #39
    BabyBilly
    Billy
    2020 TRD
    Lame. That hitch does sit down really low. Although as some others have said I'm sure there will be plenty of aftermarket options soon enough to cut that thing off and replace with something higher clearance.
  20. Apr 8, 2025 at 8:34 AM
    #40
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Has anyone found an aftermarket bumper that relocates the trailer hitch?
