I cant find anything!!!
Discussion in 'Lighting' started by tacomathunder, Feb 15, 2010.
  1. Feb 15, 2010 at 5:20 PM
    tacomathunder
    tacomathunder [OP] Well-Known Member
    Florida
    07 4 cyl reg cab
    pop-a-lock on tailgate, tailgate damper by ez down, extang platinum snap tonneau cover, rampage LED light bar, etrailer wiring harness, black led tail lights, tsi clutter catcher center console, griffin itrip ipod player,BHLM,35W DDM Tuning hid's 5000K, Day Time Running Light Mod, New Sony Stereo
    hey guys, sorry i have been a real bother over this, but i cant find any detailed instructions on how to install foglights onto my base taco....is there a write up somewhere that shows/tells how exactly to do it
  2. Feb 15, 2010 at 5:26 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
  3. Feb 15, 2010 at 5:28 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    ok here goes nothin:
    first find the white with green stripe wire in the coin holder pocket(remove the coin holder first). this will be the acc. power(hot when key is on). wire the lights acording to the instructions.
    usually constant hot to a relay then wire to lights from relay. hot from acc. power to a switch then from the other side of switch to relay. and then a ground to relay. the lights themselves will also need a ground(something metal)
    this will allow the lights to come on anytime the key is on.
    sorry no pics
  4. Feb 15, 2010 at 6:01 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
  5. Feb 15, 2010 at 6:28 PM
    rhodehard09
    tampa, fl
    its really not that hard just take your time
  6. Feb 15, 2010 at 6:31 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    im kinda worried about messing my wiring up...then gettin F'd over
  7. Feb 15, 2010 at 6:32 PM
    rhodehard09
    tampa, fl
    the worst you will do is pop a fuse.
  8. Feb 15, 2010 at 6:37 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    and your way will have them on all the time... i would like to have controlability
  9. Feb 15, 2010 at 9:31 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    Dude! He is telling you about a power source that is powered only when the key is turned on. He also told you what wire to run to a switch and then to the relay. I mean how much more controlability do you need? The lights will only work when the key is turned on, and you have the switch for the fog lights to be turned on or off. What he is saying about anytime is you do not have to have the head lights turned on to run the fog lights. It will be wired where you can turn on just the fog lights by themselves or have them on with the headlights. On a factory wired set when you turn on the high beams the fog lights will turn off till you go back to the low beams and the fogs will only work with the headlights on. The way he told you allows you to keep them on whenever in any headlight position (high/low beams). When you turn the ignition key off it kills the fog lights because your power is coming from a key controlled power source.
    Murph
  10. Feb 16, 2010 at 1:55 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    o ok, sorry for the mis understanding, that clarifies things for me
