I cant get my struts assembly back on after adding lift
Discussion in 'New Members' started by guitargeek99, Nov 10, 2012.
  1. Nov 10, 2012 at 11:46 AM
    guitargeek99
    guitargeek99 [OP] Member
    Ken
    Dalton Ga.
    1998 tacoma, 4x4 on 32/11.5/15 goodyear mt wi
    3 inch suspension, new rear 9000 shocks and leaf springs,new KYB struts. ne wtires
    I just had my springs compressed and new struts put in and I cant get them to go back on the truck, there is just not enough room . I even took off the control arm and they still wont fit , I wanted to get my tires today please help SOS
  2. Nov 10, 2012 at 11:51 AM
    guitargeek99
    Ken
    Dalton Ga.
    well I had to take it off on the top where there is a horizontal bolt about 8 inches long that allowed the control arm to move down freely
  3. Nov 10, 2012 at 11:52 AM
    guitargeek99
    Ken
    Dalton Ga.
    I am not sure how far down I can push hub, its pulling the axxle out to where the boots are tight
  4. Nov 10, 2012 at 11:54 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What lift are you installing?
  5. Nov 10, 2012 at 11:54 AM
    guitargeek99
    Ken
    Dalton Ga.
    tuff country 3 inch susp. lift
  6. Nov 10, 2012 at 11:56 AM
    Pugga
    Massachusetts
    F-150 Mod
    Is that a top plate spacer? If so, they are tough to stuff in there. You can loosen the LCA to get some extra play.
  7. Nov 10, 2012 at 11:57 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    pry between the lca and the frame....or use a jack off the uca and the top of the fender
  8. Nov 10, 2012 at 11:57 AM
    guitargeek99
    Ken
    Dalton Ga.
    Thanks I did , Ihave to where I can pull down on it until the boots on the axle are tight , how far can I pull down?
  9. Nov 10, 2012 at 12:00 PM
    guitargeek99
    Ken
    Dalton Ga.
    I am going to try the spring compressor from Auto Z, and see if that will help, the directions didnt say how much of a pain in A#$ thisis . it will be worth it
  10. Nov 10, 2012 at 12:03 PM
    DD03SR5
    DD03SR5 Well-Known Member
    Derek
    Ontario,Canada
    03 SR5 4X4
    Deckplate,5100's,eibach's,Wheelers AAL,
    you may have to disconnect your sway bar.finish the lift and then re connect. you may still need a buddy and a really long pry bar
  11. Nov 10, 2012 at 12:06 PM
    guitargeek99
    Ken
    Dalton Ga.
    OK, Ill try it, thanks for the feedback, I am going back out to my shop,
    you yota is sure nice , I will post a pick when I get mine done,
  12. Nov 10, 2012 at 12:06 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    DO NOT PRY ON ANYTHING!! loosen LCA bolts until LCA drops down then put strut in.
  13. Nov 10, 2012 at 12:08 PM
    guitargeek99
    Ken
    Dalton Ga.
    I am very careful not to pry to much , thats why I think if I can compress the the srtrut assembly , then put it in , and reconnect the lca,
  14. Nov 10, 2012 at 12:53 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    +1 on the sway bar being disconnected at the links. Loosen control arms bolts then tighten once you have all the nuts and bolts back in place.
  15. Nov 10, 2012 at 2:38 PM
    guitargeek99
    Ken
    Dalton Ga.
    success!!! I had to disconnect the LCA and the sway bar then remove a clip for the brake line then it went in with minimum hammering and prying , I am new to this wab site and so far found it very useful , I really appreciate the feed back I will post some pics when I get done. Thanks everyone.
