I can't sell my truck.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hualampeter, Nov 25, 2013.
  1. Nov 25, 2013 at 7:59 PM
    #41
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
  2. Nov 25, 2013 at 8:21 PM
    #42
    Toyotacerttech
    Toyotacerttech Well-Known Member
    Michael
    Texas
    2011 double cab 4x4 TRD
    1gr-fe is an interference engine
  3. Nov 25, 2013 at 8:46 PM
    #43
    BamaToy1997
    Bill
    Navarre, FL
    Removing the valve covers and showing you the upper valve train doesn't prove squat. Sounds like the guy is trying to blow smoke you-know-where.
    Late to the dance. Already mentioned. lol
    I would like to see documentation supporting that. All of my info says the 1GR-FE is a non-interference engine.
  4. Nov 25, 2013 at 9:15 PM
    #44
    Toyotacerttech
    Michael
    Texas
    It's in the Toyota repair manual when it describes how to install the camshafts
  5. Nov 25, 2013 at 9:27 PM
    #45
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    So was it camshaft failure :eek: OP
  6. Nov 25, 2013 at 10:18 PM
    #46
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  7. Nov 25, 2013 at 11:18 PM
    #47
    hualampeter
    hualampeter [OP] Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
  8. Nov 25, 2013 at 11:59 PM
    #48
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  9. Nov 26, 2013 at 12:11 AM
    #49
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    camshaft position sensor went crazy in both bank 1 and 2.
  10. Nov 26, 2013 at 6:00 AM
    #50
    BamaToy1997
    Bill
    Navarre, FL
    Hm. I am looking at it right now for the 2005 1GR-FE engine (OP has a 2005 according to information) and the Toyota repair procedure says nothing about it being an interference engine. It says "NOTICE: Keep the camshaft level while it is being removed. The camshaft thrust clearance is very small and failing to keep it level could crack or damage the cylinder head journal surface, which receives the thrust. This could subsequently lead the camshaft to seize or break. Perform the following steps to avoid such problems" but that has nothing to do with valve/piston interference. It has to do with the camshaft thrust clearance and bearing caps.
    Interesting that there has been more than one engine rebuild that has resulted in a timing chain being broken. I am curious. Chains do not normally just "break" like that. I am beginning to think that perhaps inferior brands are being used, instead of Toyota brand in this case?
    OK, I found this information on replacing the cylinder head. This does verify that the engine is in fact an interference engine as Toyotacerttech has indicated! I always like to see something in print before blindly accepting it. And here it is. A notice when replacing the cylinder head during an engine rebuild.
    "NOTICE: Installing the crankshaft at the wrong angle could cause the piston head and valve head to come into contact with each other when installing the camshaft. This could cause damage, so always set the crankshaft at the correct angle."
  11. Nov 26, 2013 at 6:19 AM
    #51
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    this is now a major failure, I would be leaning towards something not installed properly with the rebuild, these engines are fairly stout...
    Many years ago I had an engine rebuilt with a local reputable and recommended shop (VW scirroco, circa 1979 or so), took it for a spin and it dropped a valve within the first 5 miles because one of the valve retainer clip popped loose (improperly installed), had it towed back, shop rebuilt it a second time, no problems on the second go round...it ate up a piston too...
    Sometimes shiza happens, hopefully he will pick up the tab on everything...
  12. Nov 26, 2013 at 6:32 AM
    #52
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    OP what was being rebuilt?
    It's not like you can easily 'rebuild' these engines. I got a new to me used low mile engine for much less than a rebuild would cost from a reputable engine shop. Just wondering how this all started off.
  13. Nov 26, 2013 at 6:35 AM
    #53
    IsmellBacon
    IsmellBacon Well-Known Member
    Denver, Colorado
    TRD offroad double cab
    None yet, need to finish the HEEP first
    She just wants you to save the money for a RING!
  14. Nov 26, 2013 at 7:06 AM
    #54
    Ham N Egger
    Ham N Egger Well-Known Member
    33.414842, -111.909319 or 36.107324, -115.175744
    09 PreRunner V-6
    Is he the guy that developed the fig newton?
    Like another poster said, get rid of the GF and the truck. Start anew.
    Honda Civic? Yikes!
  15. Nov 26, 2013 at 1:34 PM
    #55
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    Well, I head a blown head gasket the first time at 185K miles. Then let the mechanic take it from there. It was a reputable shop, until my chain snapped... He's picking up the tab for sure, its under his warranty. But, it seems like I should just sell this truck or get a new engine. I have so much coin invested into the dam beast...
  16. Nov 26, 2013 at 1:38 PM
    #56
    XXXX
    sKiP
    05 Prius
    So he replaced the head gasket and it's their fault for the timing chain?
    FYI I found my engine for $1,250.00 and it has LOW miles on it. Transporting it across country + finders fee's I gave to the member who found it made it about a 2k purchase.
  17. Nov 26, 2013 at 1:44 PM
    #57
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Someone should find out concretely if the engine is an interference or not.. Cuz if its not i'd not go back to that dude
  18. Nov 26, 2013 at 3:42 PM
    #58
    RedlineTRD
    RedlineTRD Well-Known Member
    Kyle
    Peyton, Colorado
    2017 Tacoma TRD OR DCSB MT
    Working on it.
    FTW
  19. Nov 26, 2013 at 4:21 PM
    #59
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    So normally the 1GR-FE engine is a non-interference engine BUT if you install the crankshaft incorrectly then the valves and pistons can come into contact, correct?
    So basically if you've never messed with the crankshaft to begin with on a non-rebuilt engine and your chain breaks, there should be no valve/piston contact.
  20. Nov 26, 2013 at 4:28 PM
    #60
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I would almost always prefer this route because most of the time it's always cheaper than rebuilding one and if not done correctly this happens. Also Toyota heads always calls for a super smooth mating surface for the head gaskets that not a normal machine shop can provide.
