I can't sell my truck.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hualampeter, Nov 25, 2013.
  1. Nov 26, 2013 at 4:30 PM
    #61
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    So much confusion in here......
  2. Nov 26, 2013 at 8:13 PM
    #62
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And that is in keeping with Toyota standard practice.
    For the most part, chains go into interference engines and belts go into non-interference engines. Some exceptions, such as the 4.7, but that is a Lexus design so a smooth, quiet engine was a requirement.
    Honda is really bad about putting belts into interference engines.
  3. Nov 26, 2013 at 8:17 PM
    #63
    Rich91710
    Rich
    Los Angeles
    08 Base
    The definition of a non-interference engine is one where the camshaft can be rotated with a piston at TDC and not make contact.
    No engine "interferes" when the camshaft is installed properly oriented with the crank, though some engines may make contact when run to RPM levels above their design due to rod stretch.
  4. Nov 26, 2013 at 10:05 PM
    #64
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    See above.
    No it's not normally a non interference engine. The definition of the non interference engine and interference engine is that in a non interference engine with the crankshaft spinning there is enough clearance between the valves and piston if the camshaft stops spinning. In an interference engine However, interference engines usually sustain damage if synchronization between the crankshaft and camshaft(s) is lost allowing the piston and valve to collide causing damage and most likely very expensive repairs for the vehicle owner.
    The 1GR-FE is classified as a interference engine and if the timing chain breaks and the crankshaft is still moving then pistons are coming in contact with valves in one or more cylinders.
  5. Nov 27, 2013 at 6:22 AM
    #65
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And it ain't going to be pretty... or cheap.
  6. Nov 27, 2013 at 9:36 AM
    #66
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Thank you. At least it's chain driven. I have not seen a broken chain under 180K miles. Honda on the other hand is a different story with their belts.
  7. Nov 27, 2013 at 1:53 PM
    #67
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    He said "Rod Stretch" :laughing:
  8. Nov 27, 2013 at 3:02 PM
    #68
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Captain Spaulding!
  9. Nov 27, 2013 at 8:34 PM
    #69
    Rich91710
    Rich
    Los Angeles
    08 Base
  10. Nov 27, 2013 at 8:37 PM
    #70
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    dont get down on your self man. I just rebuilt my engine at 250,000. then spent a couple more times taking it in and out to fix oil leaks and such. Now i broke the end off my crank and just pulled it again and a nother $1000 in parts and now it is coming out again tomorrow morning to fix some other problems that were not caught before. I will never sell my truck though because of it....
  11. Nov 28, 2013 at 10:51 PM
    #71
    hualampeter
    hualampeter [OP] Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    When I get my truck back, I will decide if its worth keeping. I don't wan't to keep forking out money to fix problems that was not my doing. Plus, since it's a 2005, I've been thinking about the rusted frames that some TW members here has encountered. I think I might just sell it and save up for a new Tacoma. THanks for your guys insight and suggestions, and happy Thanksgiving :)
  12. Nov 29, 2013 at 1:06 AM
    #72
    Rich91710
    Rich
    Los Angeles
    08 Base
    San Jose California? I don't think you need to worry about rust unless you live right on the water or trailer a boat to a salt-water marina.
    Worst we get is some light surface rust... if they aren't salting the roads, your frame will last just fine.
  13. Dec 12, 2013 at 5:22 PM
    #73
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    Update: Passenger side valves are bent. Mechanic is replacing the whole head on the passenger side.
