I changed the oil but forgot to change the crush washer. Now I have a very tiny leak.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Sep 7, 2022.
  1. Sep 7, 2022 at 10:13 AM
    5efvz
    5efvz [OP] Well-Known Member
    I'm going to just undo the bolt, replace the crush washer and put it back on as fast as I can. And catch the oil in a fresh container.
    Any tricks I should know to minimize oil loss?
  2. Sep 7, 2022 at 10:26 AM
    5efvz
    ok
    Taco critter likes this.
  3. Sep 7, 2022 at 10:40 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Best way to do it is have another person use their finger to plug the hole when you remove the drain plug. Then put the crush washer on and put the plug back on. If you're good, you won't lose any oil.
  4. Sep 7, 2022 at 10:45 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    wilcam47, Wulf, 5efvz[OP] and 2 others like this.
  5. Sep 7, 2022 at 10:53 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Did you torque the bolt to spec? I’m an advocate of changing the washer with every oil change, but tons of folks report reusing those washers multiple times with no ill effects.
  6. Sep 7, 2022 at 11:08 AM
    5efvz
    Like perineum sunning.
  7. Sep 7, 2022 at 11:09 AM
    5efvz
    I don't use a torque wrench but I'm pretty good at guestimating. I think because the bolt is somewhat corrored due to salt, the seal isn't as good as it could be.
  8. Sep 7, 2022 at 11:13 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Wine bottle cork while changing the crush washer...?
    5efvz[OP] likes this.
  9. Sep 7, 2022 at 11:22 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    There was a similar thread just like this, except the washer was new. Owner hadn’t torqued to spec. That was recommended and he found that the bolt was significantly under tightened. That’s more likely with a new washer but, easy thing to try and highly recommended.
  10. Sep 7, 2022 at 11:24 AM
    5efvz
    I will recheck torque.
  11. Sep 7, 2022 at 11:40 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  12. Sep 7, 2022 at 11:48 AM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Not that it solves your issue, but I have had good luck flipping the crush washer so the "old" crushed side is on the bolt side. The old flat side gets crimped into the gap and seals well.
    I have only done that twice, but it hasn't leaked either time.
    You don't want to use them more than twice that way, of course.
  13. Sep 7, 2022 at 1:26 PM
    ppham444
    Phuong
    Portland, OR
    I use a similar technique with my boxers. After two days of wearing, I flip it inside out and wear them another three days. Save me from doing too much laundry.
  14. Sep 7, 2022 at 1:34 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    :rofl:
  15. Sep 7, 2022 at 4:27 PM
    O'Silver_Taco
    MD
    Oh......You dont have to replace a crush washer everytime.....
    you just got to develop a feel for it......
    dont over crush it to start with.......dont reuse old old stuff....it just splits...like old lumber......
    And hell its hotter than hell here in the south.....
    this time of the year.......I pretty much live in my boxers.......
    the Calvin Klien ones that look like running shorts.....
    5efvz[OP] and Wulf like this.
  16. Sep 7, 2022 at 5:16 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I tried this with socks and after 48 hours they walked away all on their own
  17. Sep 7, 2022 at 8:31 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    5efvz[OP] and Nessal like this.
  18. Sep 8, 2022 at 6:06 AM
    snaggs
    snaggs Well-Known Member
    Shaun
    Nova scotia , Canada
    2001 tacoma sr5 2.7 4x4
    None
    What gilligoon suggested will work if you dont want to buy a new one, done that a few times.
  19. Sep 8, 2022 at 7:13 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Same. I wish the oil filter was located in a different spot like the 2nd gens. It make a mess and with heavy aftermarket skids, it gets annoying.
  20. Sep 8, 2022 at 7:15 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Keep an eye on your oil level !
    I changed a few over the years that the washer was missing .
    only in one case did all the oil leaked out over night
    5efvz[QUOTED][OP] likes this.
