I did a little MAF refresh.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cmdocpro, Mar 8, 2022.
  1. Mar 23, 2022 at 3:18 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Hell yeas!
  2. Mar 23, 2022 at 4:26 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    I’ve read that the K&N air filters eventually cause more harm down the road. I opted to go with cheap OEM replacements as needed
  3. Mar 23, 2022 at 4:34 PM
    Cmdocpro
    Cmdocpro [OP] Well-Known Member
    2006 DCSB Off Road
    It'll be getting the trd intake before long
  4. Mar 23, 2022 at 4:42 PM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    I've never seen such a dirty MAF. Never had to clean either my 2004 or 2002 Chrysler. throughout the life of the vehicles..both of which I drove for 17+ years. Then again I change air filters every so often. I wonder if there was a leak around the air filter. I suggest you change the oil and re-examine the filter housing just to be safe.
  5. Mar 23, 2022 at 4:46 PM
    Cmdocpro
    2006 DCSB Off Road
    I cleaned the entire air pathway inside and out and the new filter seals up tight. Only point of compromise was the foam seal at the fender but I don't think that would have caused it. I did replace that seal with weatherstripping.
  6. Mar 23, 2022 at 4:49 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I understand that you "read" it, but what do you think is the cause?
  7. Mar 23, 2022 at 5:47 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Go buy an OEM Toyota filter, they filter the best and are far superior to the KnN
    Island Cruiser likes this.
  8. Mar 23, 2022 at 5:57 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Did you clean the 2 MAF sensors elements down inside the rectangular tube of the MAF sensor, or just the IAT (intake air temp) thermistor bulb shown in the photo? Many don’t know the difference, and unknowingly skip cleaning the actual MAF sensor elements.
    I’ve found MAF sensors foul up pretty badly in heavy forest fire smoke too, and speaking of that, mine is probably due for a good cleaning after last years fires.
  9. Mar 23, 2022 at 6:10 PM
    Cmdocpro
    2006 DCSB Off Road
    I ran a healthy dose of the cleaner down the tube
  10. Mar 23, 2022 at 6:49 PM
    Waasheem
    Waasheem
    2007 xrunner
    Uhh, uh oh.
  11. Mar 23, 2022 at 8:33 PM
    Island Cruiser
    Kauai
    Baja
    If I recall(read it many beers ago), the oil catches dirt quicker(as intended) which in turn restricts air flow quicker. The most common issue is people over-oiling them
  12. May 18, 2022 at 4:36 PM
    Wile_E_RedDog
    Wile_E_RedDog Well-Known Member
    Terry
    Sacramento, CA
    2008 Silver Tacoma OR Baja DCSB
    AT Overland Summit,
    From what I've read here on TW and other places, it is actually the fine particulate matter that K&N and other oil air filters suffer from. I ran a K&N on my Toyota pickup (loved the sound and additional snap) and was planning to run one on my Tacoma but decided against it after finding this issue repeated close to every forum I checked for stats on K&N filters.
  13. May 18, 2022 at 5:12 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    That is pretty damn dirty. Great job cleaning it though!
