i did my oil change today
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockyTacoma, Aug 7, 2010.
  1. Aug 7, 2010 at 9:13 PM
    RockyTacoma
    RockyTacoma [OP] Well-Known Member
    Dojo
    colorado
    2002 tacoma trd
    stock
    i did oil change on my 02 TRD, to bond with my truck. fock!!! it was pain in the ass. 6 quarts and oil filter cost me $25 at toyota dealer, and i had to remove the front skid plates to get to oil filter 3.4L. next time, i will fork out $35 for toyota do the oil change. saving $10 wasn't worth it.
  2. Aug 7, 2010 at 9:15 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Go through the drivers side wheel well next time to get to the filter. Much easier.
  3. Aug 7, 2010 at 9:18 PM
    RockyTacoma
    Dojo
    colorado
    2002 tacoma trd
    stock
    ....wheel well has some kind of cloth cover on it. can i remove it and reattach it?
  4. Aug 7, 2010 at 9:25 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I could be wrong (and probably am) but can't you get to the oil filter from the wheel well area on your year? Also... you bought the oil from the dealer? It's cheaper from an auto parts store or wallyworld. Don't give up...just find a better way next time. Doing it youself is the best way to know it's done right. There's been horror story after horror story on dealershhips and oil change places screwing things up...don't give them the chance!!
  5. Aug 7, 2010 at 9:27 PM
    OffroadToy
    Yep, just attached with plastic clips. If you break a clip just go to the auto parts store and buy a few extras.
  6. Aug 7, 2010 at 9:32 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I remove my skidplate everytime I do an oil change too....I think its easier to get to from underneath compared to from the wheelwell.
    I kinda wish I still had the stock skidplate....dropping the Budbuilt then bolting it back up sucks lol.
    oh and if you ever switch to synthetic expect to pay a good bit more...my dad takes his car to jiffy lube and said that for me to get my truck done there it would cost over $100 :laugh:
  7. Aug 7, 2010 at 9:33 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    yup, pretty easy to do, i do believe you can just use a flat screw driver to pull out the fastener. kinda check it out before you start prying on it though, just in case
  8. Aug 7, 2010 at 9:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    as the others said, yes you can. Just use a flat screwdriver to pop them out. The filter will be right in front of you once that rubber flap thing is out of the way. I also drop the rear skid to keep the mess to a minimum since the filter spills oil everywhere.
  9. Aug 7, 2010 at 9:38 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I would just pay the extra $10 and don't worry about it.
    I see why toyota changed where they put the oil filter. Oil changes on my 09 (V6) are so easy!
  10. Aug 7, 2010 at 10:00 PM
    OffroadToy
  11. Aug 7, 2010 at 10:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It isn't about saving money for me. Its about taking full responsibility. And, as others have mentioned, not giving some minimum wage earning kid a chance to mess things up.
    Besides, what better way to spend a Saturday afternoon and bond with your truck.
  12. Aug 7, 2010 at 10:22 PM
    ccoliver09
    ccoliver09 Member
    California
    00 Tacoma PreRunner
    CB Radio Tow Hitch Fog Light Mod Deck Plate Mod
    Just did my oil today on my 2000 2.7L Tacoma pre-runner every time I get the filter off I always spill oil on my skid plate. Is there any Tips or Tricks to prevent this besides removing the plate or (What I've been doing) put a rag under the filter.
  13. Aug 7, 2010 at 10:32 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I use an old walmart bag and wrap it aound the filter and unscrew it...
    OP dont buy oil from the dealer. i buy it at walmart and can get synthetic with filter for $30. itd be like $10-$12 for dyno oil
  14. Aug 7, 2010 at 11:09 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Good tip.
    I just reach down from the top of the engine to take it off and replace it.
  15. Aug 7, 2010 at 11:18 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i reach the filter through the engine compartment,just reach under the alternator and you can grab it
  16. Aug 7, 2010 at 11:19 PM
    Tacomadude89
    Austen
    Exactly.
  17. Aug 8, 2010 at 5:13 AM
    Barnone
    Barnone Guest
    DIY is the way to go. Go read the stories in 2nd about dealers and quick change places. I always change my oil/filter on the gravel so a few drops of spilled oil does not bother me.
  18. Aug 8, 2010 at 8:23 AM
    RockyTacoma
    Dojo
    colorado
    2002 tacoma trd
    stock
    .....it was pain, but i enjoyed the exprience. next time i will try the engine compartment route.
  19. Aug 8, 2010 at 11:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You?
  20. Aug 8, 2010 at 2:09 PM
    kn38ms
    kn38ms Well-Known Member
    NW, FL
