I did not know this.......
Discussion in 'Technical Chat' started by chris4x4, Dec 14, 2008.
  1. Dec 14, 2008 at 6:46 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Back in the day (carberated engines) when flooded, you "floor" the gas peddal and crank to start the vehicle. WELL, in the days of computer controled ignitions and all, if your engine becomes "flooded", which can happen if the fuel injectors leak down when the engine is shut off, "Flooring" the accelerator sends a signal to the ECU to not fire the injectors, allowing a "flooded" engine to be started.
    I just found this out, and thought it interesting. :)
  2. Dec 14, 2008 at 7:18 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    They flood out more than one would think.
    Say you go to clean out the garage, move the car(s) out. Get the job all done then go to fire em back up. Crank no start, WTF?? The SAI system never completed it's warm up cycle, i.e. rich run condition, fuel soaked plugs.
  3. Dec 14, 2008 at 8:02 AM
    missileman125fw
    missileman125fw Well-Known Member
    That is very interesting. And very good to know. Thanks
  4. Dec 15, 2008 at 11:20 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    learned this froma mechanic buddy a few years back...i called BS and then ate some humble pie. :rolleyes:
  5. Dec 15, 2008 at 11:57 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Thanks for sharing the knowledge. :)
  6. Dec 15, 2008 at 12:09 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    sweet, I always thought that would make the problem worse. Thanks for the heads up on it!!
  7. Dec 15, 2008 at 12:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    after i clean my throttle body, when i go to crank the truck(or car for that matter) i always rev it til it fully cranks. seems to be flooded a bit after cleaning the tb.
