I did some height measurements of my 2012 Sport today...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larry, Jul 25, 2012.
  1. Jul 25, 2012 at 8:07 PM
    Larry
    Larry [OP] CARL
    CARL
    and the truck stance is one half inch higher than the 2010 SR5 I had.
    I assume this is the 17" sport alloys.
    also the rear stance is 1/2" higher than the post TSB measurements on my SR5.
    I assumed Toyota raised the front to compensate for the higher 4-leaf pack. maybe I'll put 5100's @.85 on the front after all to level the stance.
    and the "taco lean" is still there. about a 1/4".
  2. Jul 25, 2012 at 8:09 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    09 Timberland Mica DC 4WD Sport
    wat?
    regardless of the wheel size, the tire size is still pretty even and wouldnt account for any height difference. how many miles on the 2010 when you measured? possibly coil and spring break in for the difference?
  3. Jul 25, 2012 at 8:15 PM
    Larry
    Larry [OP] CARL
    CARL
    2010 was about one month old when I documented the measurements pre TSB and post TSB.
    this new sport is 1/2" all around higher than the post TSB measurements.
    I figure it was the wheel/tire that made the 1/2"
    2010 had 16" steelies w/ 245's
    2012 has 17" alloys w/ 265's
  4. Jul 25, 2012 at 8:16 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    bold makes no difference as that is the tire width. the next number is what matters as that tell you the percent of width that makes the sidewall height
  5. Jul 25, 2012 at 8:18 PM
    jhodge83
    SC
    wat?
    check the attached image for diameter difference...
  6. Jul 25, 2012 at 8:21 PM
    MJLGUTH
    MJLGUTH Active Member
    Matthew
    Denver, CO
    2012 Tacoma DCSB TRD Sport
    What were the measurements of the 2012? And where are you measuring from (center of hub or ground up)? I am trying to get an accurate gauge on my lift and I forget to pre measure my stock 2012 sport. Thanks.
  7. Jul 25, 2012 at 8:24 PM
    Larry
    Larry [OP] CARL
    CARL
    interesting
    so, the 17" sport Bridgestones actually have less side wall height then the 16" Dunlaps that were on my SR5? giving almost the same overall diameter fron hub/center?
  8. Jul 25, 2012 at 8:25 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Yes
    Where's the measurements ?
  9. Jul 25, 2012 at 8:27 PM
    08pretaco
    Oliver
    az
    can we merge both of his threads into one lol
  10. Jul 25, 2012 at 8:37 PM
    Larry
    Larry [OP] CARL
    CARL
    from ground up:
    LF = 34-1/2"
    RF = 34-3/4"
    LR = 37"
    RR = 37"
  11. Jul 25, 2012 at 9:03 PM
    OZ-T
    Peter North
    British Columbia
    Boooo
    Hub to fender ?
  12. Jul 26, 2012 at 6:08 AM
    floridaoccifer
    floridaoccifer Civil Servant
    Larry, I set my billies at 1.75" on my 2012 and had the same type of lean until the suspension finally settled in. As of right now my difference is less than 1/8"...
    You may want to give it a few weeks/month depending on how much you drive it.
  13. Jul 26, 2012 at 7:25 AM
    Larry
    Larry [OP] CARL
    CARL
    LF = 20 - 1/4"
    RF = 20 - 1/2"
    LR = 22 -1/2"
    RR = 22 -1/2"
    I both measuring from the ground or the hub...the the truck sits 1/2" higher than my 2010 did.
    I even have dimensions from the ground to the body (cab) pinch welds...again, 1/2" higher on the 2012.
  14. Jul 26, 2012 at 7:26 AM
    OZ-T
    Peter North
    British Columbia
    Thanks Larry
  15. Jul 26, 2012 at 7:30 AM
    Larry
    Larry [OP] CARL
    CARL
    welcome
    I thought it was the wheels (1" taller wheel, 1/2" from center...netting a half inch higher stance) but looks like that is not the case.
    maybe the TRD Sport shocks have something to do with it?
    reason I'm going down this road of questions: I figured at 1st look, Toyota had made a front height adjustment since the Sport now comes from factory w/ the 4-leaf rear. apparently not so.
    so, I may add the 5100's @ .85 to the front to level the stance a bit. (especially since I have a set of four 5100's in my garage new in the box)
    thanks
  16. Jul 26, 2012 at 12:35 PM
    OZ-T
    Peter North
    British Columbia
    My '09 Sport came with the 4 leaf pack but had a similar front measurement to what you posted
