I did something I shouldn't have.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Markcal, Nov 12, 2016.
  1. Nov 12, 2016 at 2:54 PM
    Markcal
    Markcal [OP] Well-Known Member
    I planned on doing a super flush of my cooling system before winter and while doing that I wanted to remove as much of the "green" Prestone antifreeze, then replace it with the Toyota equivalent "pink" antifreeze - Zerex Asian.
    I read in my Haynes manual to do a proper flush the thermostat is removed, then idled 10 minutes. I decided to drain the antifreeze, remove the thermostat, add Prestone cleaner/flush with deionized water and instead of just idling it for 10 minutes, I drove it for about 80 miles over 3 days.
    I didn't realize without the thermostat it would run rich, causing carbon build up, with the unburned gas. I did notice black residue inside the end of my tail pipe and I just changed my oil before removing the thermostat.
    Should I change my oil again, incase unburned gas is in my oil and is there anything else I should do? I had planned to change my spark plugs Monday before this happened anyway.
    ChadsPride likes this.
  2. Nov 12, 2016 at 3:07 PM
    homesteader
    homesteader Well-Known Member
    Southern Quebec
    2017 TRD SPORT DCSB
    Just keep driving it, it will clean out within a few miles!!!
  3. Nov 12, 2016 at 3:09 PM
    Markcal
    OK, should I be worried about the oil being diluted with gas and would it be worth changing it out just incase?
  4. Nov 12, 2016 at 3:10 PM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Next time you fill up take the premium and give it a good ride ;) should be fine then
  5. Nov 12, 2016 at 3:10 PM
    homesteader
    Southern Quebec
    2017 TRD SPORT DCSB
    If your oil gets up to temperature the gas will evaporate
  6. Nov 12, 2016 at 3:12 PM
    Markcal
    OK, lesson learned about the proper way to do a coolant flush for next time.
  7. Nov 12, 2016 at 3:12 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Why do you think without the thermostat it will run lean, and why then would there be unburned gas and carbon buildup. Either way lean or rich, 80 miles is nothing, your oil is fine.
  8. Nov 12, 2016 at 3:13 PM
    Kemosabe
    Louis
    My father ran a few old trucks without thermostat because they causing problems back in the days and it didn't cause any problem with gas in oil. It is not like you would have drown it like and old skidoo or atv lol should be fine. Like @homesteader said, it will evaporate.
  9. Nov 12, 2016 at 3:13 PM
    Markcal
    OK, I didn't realize it would burn off and not cause wear.
  10. Nov 12, 2016 at 3:15 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I would be more worried about your catalytic converters. You have been sending unburnt fuel thru those cats for the duration that your were running rich.
    Get that thermostat changed and run the truck normally. It should clean out those cats just fine.
  11. Nov 12, 2016 at 3:15 PM
    homesteader
    Southern Quebec
    2017 TRD SPORT DCSB
    It probably ran cold on open loop...
    I always thought engines ran hotter with out the thermostat, not enough saturation time in the engine or the radiator
  12. Nov 12, 2016 at 3:16 PM
    Kemosabe
    Louis
    Straight, but true!
  13. Nov 12, 2016 at 3:17 PM
    Markcal
    Without the thermostat it runs in an "open loop", as it never reaches operating temperature.
    When the engine is first started the system goes into open loop operation. In open loop, the ECM calculates the Air/Fuel ratio based on inputs from the coolant and MAF sensors. The system remains in open-loop until the following three conditions are met:
    • Coolant temperature above 105°F.
    • Oxygen sensor has varying output voltage (indicating it is hot enough to operate properly).
    • A specific amount of time (preprogrammed into the MEM-CAL) has elapsed.
  14. Nov 12, 2016 at 3:21 PM
    Markcal
    I agree, and it has been flushed with the thermostat replaced = lesson learned.
  15. Nov 12, 2016 at 3:22 PM
    worthywads
    No kidding, but with no thermostat it will reach 105F. You are way overthinking this.
  16. Nov 12, 2016 at 3:23 PM
    SpeedwayBlue116
    SpeedwayBlue116 Well-Known Member
    06 TRD Sport Speedway Blue
    If your worried about carbon or gas on your oil, personally I would change it. Carbon puts a ton of wear on your crank bearings and honestly what's an oil change gonna hurt
  17. Nov 12, 2016 at 3:26 PM
    Markcal
    I agree, but new trucks have an ECU That control fuel output.
  18. Nov 12, 2016 at 3:32 PM
    tacotech72
    tacotech72 Well-Known Member
    Northern California
    2017 Mag Gray TRD OR DCLB
    Tinted windows, roof rack, snug top, bed rug, steps, bed step
    Change the oil. Pay a technician to do it next time. There nothing like a trained person for the job, not saying you can't do it.
  19. Nov 12, 2016 at 3:35 PM
    Markcal
    Yeah, but I get satisfaction doing it myself, when it's done right and this taught me what not to do next time.
    Pigpen and tacotech72[QUOTED] like this.
  20. Nov 12, 2016 at 3:43 PM
    Markcal
    Yeah, it may be worth doing it just for peace of mind, after doing a smell test and check the viscosity.
