I didn't expect this when I change the fluid in my rear diff.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guitars&tacos, Jul 19, 2013.
  1. Jul 19, 2013 at 5:56 AM
    guitars&tacos
    guitars&tacos [OP] Well-Known Member
    North Metro Atlanta
    2018 White TRD 4x4 Off Road 6 MT
    I was shocked when I changed my rear diff fluid last night. I AM using synthetic (Mobile 1 75-90) so I figured I could go a good bit longer. I put this stuff in 50k miles ago so I thought it would be due for a change. I remeber when I drained the stock fluid it looked really dark and dirty with no clearness whatsoever.
    I suppose next time I will let it go longer because even after 50k it looked extremely clear still as you can see below. What kind of intervals are you guys getting from synthetic rear diff fluids?
  2. Jul 19, 2013 at 6:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Get it analyzed before you start extending intervals. Looks is just one part of the equation...
  3. Jul 19, 2013 at 6:13 AM
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    Not sure, but isn't it in the manual to have it changed at 100,000 miles?
  4. Jul 19, 2013 at 6:17 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Looks pretty normal to me for 50K. Drain it through a coffee filter and see if you have any magnetic particles larger than what you already picked up.
  5. Jul 19, 2013 at 6:44 AM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    My diff oil looked bad at 900 miles. When you build differentials you run them through a break in cycle and change the oil before running them as normal (similar to engine break in). Once that initial break in takes place the ongoing wear should be minimal.
  6. Jul 19, 2013 at 7:07 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I'm pretty sure it's normal for oil to go dark/black. Doesn't mean there is a problem!
  7. Jul 19, 2013 at 7:12 AM
    guitars&tacos
    North Metro Atlanta
    I am just pointing out the fact the Mobile 1 stuff looks much cleaner than the regular ol' oil that I saw come out of there at 45k miles.
    I suppose for $30 worth of oil and the 30 minutes it takes to do this service it is a deal. There's just something about seeing drained fluids look so nice when they come out. Makes me feel like my diff is nice and clean inside as well.
    I may try the coffee filter trick. I DID run a strong magnet through the used stuff and you can kinda see from the pic what it picked up.
  8. Jul 19, 2013 at 7:14 AM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Heh, I went 15 years and 145k miles on the original diff, trans, trans case oil in my 1st gen. Recently lifted and regeared and its all shiny new again. I changed after 1k miles following the regear.
