I do not know how long it will take...
Discussion in 'Trip Reports' started by Waterloo Wonder, Jan 23, 2023.
  1. Mar 26, 2023 at 5:39 PM
    Waterloo Wonder
    Waterloo Wonder [OP] Waterloo Wonder -
    Forrest
    New Hampshire
    21 Access Cab - Army Green,
    Stage 2 planning begins.
    At the end of April, I will return to Burnsville Virginia and pick up the TAT and head through VA and into NC and to at least the TN boarder. Planning to start the morning of the 30th and go for three days. More to come as I plan.
  2. Mar 28, 2023 at 2:43 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Hope you are having a good time.
    You may want 2 batteries or a jump pack running the frig etc and you can buy a cheap plugin voltage gauge/usb to see battery status.
    The stock tires may become an issue.
    The stock step bars may get you hung up and are not sliders.
    Do you have a way to securely stow that winch in the bed. Everything heavy should have a secure tiedown thought out.
    Aftermarket skid plates can be your friend as in the east mud (what's in that hole) and west rocks (where did that hit).
    You will be figuring it all out as you go so travel on!
  3. Mar 28, 2023 at 4:29 PM
    Waterloo Wonder
    Forrest
    New Hampshire
    Thanks for the reply. I am having a good time. I am solo running.
    I have a 500 watt knock off Jackery that I am using for the fridge. I keep it plugged into the 12 volt bed outlets during the driving day to stay charged and plug the fridge into it. It keeps the fridge running over night when running on its own. I have two 12volt outlets in the bed and one of those is a voltage gauge.
    Winch stays attached to the front when driving and in my garage when not in use.
    Gonna let the stock tires wear out then upgrade. For the most part on these sections it has been no worse than forest service roads.
