I dont know what Im doing, and its the sellers fault!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by orangeracer, May 8, 2018.
Thread Status:
Not open for further replies.
  1. May 8, 2018 at 3:01 PM
    #461
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    The instructions are for orienting, and to buy lubricant for re-application. The parts ship lubricated from the test fit, which his guy removed.
    tonered, cruetes and hiPSI like this.
  2. May 8, 2018 at 3:02 PM
    #462
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Same thing applies to engine building at a machine shop . are you or not going to run a tap thru all the bolt holes on the engine block and cyl heads to clean the oil and debris . Or are you going to blame fault on the machine shop when you snap a head bolt
  3. May 8, 2018 at 3:03 PM
    #463
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    *which you also know would be removed*
    You're acting like this guy went out on his own to get it cerakoted. What I gathered from the PM convo is that he was also helping you out, as (I'm guessing here) you would like to add cerakote as an option for future sales. I say that because of this.
  4. May 8, 2018 at 3:06 PM
    #464
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    And I also knew that his cerakoter would give him care/lubrication instructions, because I am not qualified for that.
    I was more concerned that he didn't know what the provided shims were for, as it turned out his guy threw them out. That part was definitely my fault.
    tonered and cruetes like this.
  5. May 8, 2018 at 3:10 PM
    #465
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    My .02 is that in this scenario, it's both parties fault/no ones fault.
    I say this, because this is a unique situation where you're both treading unknown waters, as this is the first time your knob has been coated. Would I be annoyed if I was OP? Shit yeah I'd be, but it comes with the territory of custom stuff. He has to accept it.
    As a vendor though, the solution would be to make and send him another knob, free of charge and chalk it up as a learning moment. Then everyone is happy and you can offer cerakote in the future, with specific instructions.
    N2DesignsInc and Doggman like this.
  6. May 8, 2018 at 3:10 PM
    #466
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    We used to argue on job sites that people were ignoring caution tape and lifting it and walking into the construction area. The plant had a meeting and one of the offenders claimed it said caution. He claimed he was cautious when he lifted the tape and walked through. The plant then had to buy danger do not enter tape because caution tape wasn’t specific enough.
    You want to argue their weren’t instructions? If you need instructions to install a shift knob and then tighten it while the threads are gummed up (the OP’s assertion) then you shouldn’t be allowed to own tools. The world can’t make fine print fast enough to combat the stupidity of those who take no responsibility for their own actions. So long as someone else perpetually has to think for you there will be more situations like this in your life.
    tonered, 4WALKER, cruetes and 3 others like this.
  7. May 8, 2018 at 3:11 PM
    #467
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    OP was made aware of piece inside to prevent galling. OP says nah fam its coo. Probably didn't check to see if it was still in there after cerakoter sprayed. Over tightens piece onto shifter in excitement and then blames op for not using supplied orientation pieces, that for all we know were tossed by the cerakoter. Has OP even contacted the Cerakoter to see if any instructions, or pieces were packaged with the part, or is OP just leaving information out intentionally because he didn't read the instructions? OP Recieved product Apr 6th and did not install until Apr 27th. OP had Ample time to inspect part for any imperfections or defects. Instead, threw caution to the wind and screwed it on.
  8. May 8, 2018 at 3:13 PM
    #468
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Looks like someone isn't keeping up in this thread.
  9. May 8, 2018 at 3:13 PM
    #469
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Unbeknownst to him, I intended to send him another knob (not now, though... Fuck no).
    I didn't, however intend on giving monetary compensation for what he spent to fix the collateral damage. There are PM's that you haven't seen about that.
    But yes, I agree with you otherwise.
  10. May 8, 2018 at 3:15 PM
    #470
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Why didn't you just come straight out and say that then? Say something similar along the lines to what I said, offer to ship him a knob, and see what he says? If he still refused, then yeah, he'd be in the wrong.
    edit: I see this quote, but I'm confused. In the messages we saw, you stated that the threads could be coated, and didn't specify not to coat the inner threads
  11. May 8, 2018 at 3:16 PM
    #471
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    That pc is not a shim, it is a zero surface to shim against.
  12. May 8, 2018 at 3:17 PM
    #472
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    how. hard. is. it. to. install. one. frigging. knob. Like sending instructions for flipping a light switch....
    tonered and TeecoTaco like this.
  13. May 8, 2018 at 3:17 PM
    #473
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do we know if OP installed the pc?
  14. May 8, 2018 at 3:18 PM
    #474
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I wanted to see how he reacted. If he kept his cool, it would have gone much better for him.
    4WALKER and tonered like this.
  15. May 8, 2018 at 3:18 PM
    #475
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Only .001 build up PER single pass coating,Cerakote requires at least 3 coats for coverage,I have been Cerakoting for 10 plus years.
  16. May 8, 2018 at 3:18 PM
    #476
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Well apparently this knob has like 5 different parts to it. So I'd say instructions are warranted.
    Well that's a pretty ridiculous thing to do, and poor customer service.
  17. May 8, 2018 at 3:19 PM
    #477
    medic2230
    Murph
    Bama! Roll Tide
    If any of it was your fault YOU are at fault. You can't fault a vendor of a product for something you did or modified. He admitted he wasn't familiar with that process. That was all on you once it left his possession. That is bs to even file a dispute with PayPal over this. Please make sure you never purchase anything from me. For full disclosure you should make PayPal aware of this thread in their decision.
    TACORIDER likes this.
  18. May 8, 2018 at 3:20 PM
    #478
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Or a sticker on a blow dryer not to immerse in water while using....keeps Darwin from poking his nasty head in places where natural selection should apply
    tonered and hiPSI[QUOTED] like this.
  19. May 8, 2018 at 3:21 PM
    #479
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Wow, just wow. If any vendor ever "waited" to see my reaction I can tell you my reaction would be blow the F* up
    Toy4me, Slashaar, Midknight and 3 others like this.
  20. May 8, 2018 at 3:21 PM
    #480
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's shit customer service on his part.
    cruetes likes this.
Thread Status:
