I dont know what Im doing, and its the sellers fault!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by orangeracer, May 8, 2018.
Thread Status:
Not open for further replies.
  1. May 8, 2018 at 3:21 PM
    #481
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Agree 100%
    EatSleepTacos[QUOTED] likes this.
  2. May 8, 2018 at 3:22 PM
    #482
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    I installed it, his wishes. I offered to keep it out for him to install after coating.
    Again, I knew nothing of cerakoting ... the main problem here is the hardness of the coating exceeding the hardness of the shifter shaft. Also, potential media trapped behind the Teflon.
    I left this to his professional. All threads were machined to least material conditions, and space was never my concern.
    Now that I have researched cerakote, and know that its hardness exceeds the shifter shaft, this is what caused it to get permastuck. The aluminum could not have possibly damaged the induction hardened shaft, but the coating can.
  3. May 8, 2018 at 3:22 PM
    #483
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  4. May 8, 2018 at 3:24 PM
    #484
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    He was present during the development process, which happened organically on this forum.
    tonered likes this.
  5. May 8, 2018 at 3:25 PM
    #485
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't really have much more to say here, so I'm gonna bounce unless tagged or quoted. IMO @7r41lbr34k3r should practice good customer service, and send @orangeracer that new knob for free. I think you should both treat this like what it is, which is a learning experience, and move on. Life's too short to get this twisted over something so minor.
    Kemosabe and PROseur like this.
  6. May 8, 2018 at 3:25 PM
    #486
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you need instructions for five pieces, then maybe you need to hire an installer. Just sayin'
  7. May 8, 2018 at 3:25 PM
    #487
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Are we reading something different? "Probably wont have to" and " not cover" aren't synonymous to the best of my knowledge.
    Comb likes this.
  8. May 8, 2018 at 3:25 PM
    #488
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    BEST 27 PAGE THREAD on this forum :D
    hiPSI and EatSleepTacos[QUOTED] like this.
  9. May 8, 2018 at 3:26 PM
    #489
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Ok let me break it down for you, there are 2 ways the knob could have seized on.
    1. Galvanic corrosion
    Requires time and electricity/corrosive environment, obviously not the cause because none of these conditions are met.
    2. Galling
    Caused by adhesion between 2 surfaces in sliding contact, aluminum is very PRONE to this. But, if the threads are correct pitch there shouldn't be enough force to cause seizure on the first time threading in, even without antiseize.
    So either
    A: The threads were too tight due to foreign material (ie cekacote or blasting media), and the increased friction caused the galling.
    Or
    B: When the shaft bottomed out and you continued to turn, the previously freely sliding threads had a lot of force put on them, and the large increase in friction caused the galling.
    So yes, while antisieze MAY have prevented this, it was your actions that caused it. You can damage any threaded connection by what you did, aluminum is just more susceptible to it. The seller is not responsible for the removal of lubricant, the failure to reapply it, failure to clean the threads before install or the over tightening. All of these are why it seized.
    tonered, cruetes and TACORIDER like this.
  10. May 8, 2018 at 3:26 PM
    #490
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    They both had done a few wrongs,that added up too a BIG mess,I think the O.P should cancel his dispute and the Vendor should send a replacement,then shake hands and call it a day.
    Slashaar, Wulf, Gunshot-6A and 2 others like this.
  11. May 8, 2018 at 3:27 PM
    #491
    slimshady
    slimshady Well-Known Member
    noneya
    NoCal
    [Current] Toyota Tacoma 2006 Prerunner Indigo Ink Blue AC
    Po Boy Bed Mat, Cali-Raised Fog lights, and more.
    When a thread tries to plot twist...
    :popcorn:
    LivinOnEdge and PROseur like this.
  12. May 8, 2018 at 3:27 PM
    #492
    lynlan1819
    Tacoma
    Lifted
    It was A for sure.
    tonered likes this.
  13. May 8, 2018 at 3:28 PM
    #493
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Embellishment, it's 2 parts. 3 if you count the Teflon insert. 4 if you count the anti seize.
    I know you didn't state the 5 parts hiPSI
    cruetes and hiPSI[QUOTED] like this.
  14. May 8, 2018 at 3:28 PM
    #494
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I am not a vendor, just a member with a very particular skill set.
    4WALKER, tonered, cruetes and 3 others like this.
  15. May 8, 2018 at 3:29 PM
    #495
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
  16. May 8, 2018 at 3:29 PM
    #496
    Cr250jumper
    The moon
    50 shades of tan©
    Not really. According to the seller he assumed there was enough room in the threads but then later realized he was wrong
  17. May 8, 2018 at 3:29 PM
    #497
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    Maybe 7r41lbr34k3r can make him a new shifter knob, but instead engrave a screenshot of the original knob on it?
  18. May 8, 2018 at 3:29 PM
    #498
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
  19. May 8, 2018 at 3:30 PM
    #499
    Cr250jumper
    The moon
    50 shades of tan©
    Semantics, vendor meaning you sold the product
    Wulf and EatSleepTacos like this.
  20. May 8, 2018 at 3:30 PM
    #500
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Should have bought the AT....
    tonered, Wulf, su.b.rat and 2 others like this.
Thread Status:
