I dont know what Im doing, and its the sellers fault!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by orangeracer, May 8, 2018.
Thread Status:
Not open for further replies.
  1. May 8, 2018 at 11:58 AM
    #161
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Ok so you buy a product, and have it shipped somewhere else. The place you had it shipped to opened said package and modify it with out you ever seeing it first. You get the modified product back, attempt to install it and it breaks.
    So here’s my questions.
    1. How do we know the person the package was sent to didn’t throw away/misplace the directions?
    2. If you recieved the product with no directions why did you not contact the manufacturer of said goods and see if there is any special directions?
    3. You over tightened the product and then want the seller to replace the item?
    It doesn’t seem like you want to truly warn anyone out there. You are trying to start a witch hunt to get your money back for your own fault. If the product didn’t come with directions yes that is the sellers fault and stuff happens, but it doesn’t make it entirely the sellers fault you put it together wrong with out contacting them until the damage had already been done. I seriously doubt you would be in this situatiom if the seller had sent you the item directly and you installed it without modification.
    You are putting off any blame from the coating applied, but will not provide pictures of the threads to prove they have not been tampered with, I wonder why that is?
    jbcanes, cruetes and morri89 like this.
  2. May 8, 2018 at 11:58 AM
    #162
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    It’s ridiculously easy on OSX:
    Shift+command+3 does a full screen shot
    Shift+command+4 does a screen grab/select where you get a cursor to select which part of the screen
  3. May 8, 2018 at 12:00 PM
    #163
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You win.
    cruetes likes this.
  4. May 8, 2018 at 12:00 PM
    #164
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Sell the potato, non seizable shift knob.
    Include instructions - Step 1 remove OEM knob. Step 2 jam potato the fuck onto lever.
  5. May 8, 2018 at 12:01 PM
    #165
    orangeracer
    orangeracer [OP] Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
  6. May 8, 2018 at 12:02 PM
    #166
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Just direct PayPal here to see all of this lol.
    On an aside those shift knobs look sweet. If I had a manual I'd hit you up for on :thumbsup:
  7. May 8, 2018 at 12:04 PM
    #167
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    One theory I have, is that blast media found its way under this teflon plug (I offered to leave this feature for him to install, it is a zero surface for shimming to get proper orientation). When he got it tight, it likely rained media down on the threads to cause the initial bind. After that, the cerakote won the battle against his shifter. Unless, of course ... we later get the proof that it wasn't coated in there.
    I don't think anyone is stupid enough to force a metal knob on.
    It literally attaches just like stock, with the exception of orientation.
    tonered likes this.
  8. May 8, 2018 at 12:04 PM
    #168
    orangeracer
  9. May 8, 2018 at 12:05 PM
    #169
    Midknight
    Western Canada
    2018 TRD Off-Road
    This ^^
    This forum is a great resource for info on how to install a wide variety of things.
    I'm a newb, but got comfortable enough to install some basic things from info on here
  10. May 8, 2018 at 12:05 PM
    #170
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Much easier on Windows. I just press the middle button on my mouse. BOOM done.
    Kinda hard to do that though with a Mac:
    mrkabc and tomwil like this.
  11. May 8, 2018 at 12:06 PM
    #171
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I could have swore the OP stated he over tightened it trying to get the shifter to align straight.. Mistakes happen but this whole situation is a cluster.
    medic2230 and tonered like this.
  12. May 8, 2018 at 12:07 PM
    #172
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Indeed.
  13. May 8, 2018 at 12:08 PM
    #173
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    :rofl::rofl::rofl::bananadead:
    cruetes likes this.
  14. May 8, 2018 at 12:08 PM
    #174
    orangeracer
  15. May 8, 2018 at 12:09 PM
    #175
    Midknight
    Western Canada
    2018 TRD Off-Road
    Thanks, but I just got a TRD Pro knob, so I'm all out of my knob budget for now :p
    cruetes and scottalot like this.
  16. May 8, 2018 at 12:09 PM
    #176
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Same all around. :)
  17. May 8, 2018 at 12:09 PM
    #177
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Here are the "instructions", FWIW. Admittedly, they could be worded a bit better. The lube that I put on the knob is from test fitting on my truck, so you can be darn sure it is on there.
    cruetes likes this.
  18. May 8, 2018 at 12:10 PM
    #178
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    You know it’s going to be a good thread when you write a response and by the time you hit post there is already two new pages to read :D
  19. May 8, 2018 at 12:11 PM
    #179
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    So the instructions OP said he never got is actually posted on the same forum he frequents on a somewhat regular basis?
    tonered likes this.
  20. May 8, 2018 at 12:11 PM
    #180
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I've learned to just assume what is going to happen next and post based of what I think will happen. If I'm wrong, I'll most likely be right in 2-3 more pages, at that point I can say, SEE! SEE!
    cruetes likes this.
Thread Status:
