I don't like it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by retroman, Apr 30, 2024.
  1. Apr 30, 2024 at 6:40 PM
    retroman
    retroman [OP] Member
    smoky mtns, NC
    tacoma
    Hey Folks:
    Here in the Smoky Mtns of North Carolina we are always either going up or down. Our Tacomas have a stepdown feature that aids in holding the truck back on steep hills. I don't like that feature and would like to disable it. I feel as tho I am torturing the transmission. I'd rather replace the brake pads over the transmission.
    About a year ago when I was having transmission troubles one of the symptoms was that the step down didn't engage. It turned out to be the "pigtail" attached to the Range Sensor on the side of the transmission. That "pigtail" also operates some vital components that are necessary to the normal operation of the truck. I need those but one of the wires signals the step down to engage when the brake is applied. Anybody know which wire I should deal with or how to accomplish the task in another way?
    My truck is an 07 base model with the 4 L engine.
    Bob
  2. Apr 30, 2024 at 6:50 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not gona hurt anything by allowing the transmission to downshift on a grade, most transmissions with a tow mode will downshift to provide engine braking when tow mode is turned on. 2nd Gens do it by default to save fuel and provide a bit of engine braking.
    If you want to change transmission behavior you would need a tune.
    The reason it probably wasn't working correctly when the range sensor was messed up is it will go into failsafe mode when it get's invalid signals from certain sensors.
    b_r_o and 3JOH22A like this.
  3. Apr 30, 2024 at 6:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Not torturing anything. The transmission isn't slowing the vehicle down. It simply downshifts to let the engine slow the vehicle down. Spinning the engine faster against a closed throttle heats up the air in the cylinders (i.e. converting kinetic energy to heat), which is easily dissipated by the cooling system.
    Dm93 likes this.
  4. Apr 30, 2024 at 7:06 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Totally fine to engine brake. Could help save your brakes for when you really need them!
    wilcam47 and Dm93 like this.
  5. Apr 30, 2024 at 7:10 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    "gears are to hold speed [up or downhill], brakes are to stop you"
    Overall it's way safer to let it do this auto downshifting when riding the brakes. The 2nd gen 5 speed auto behind the V6 will downshift for speed holding all the way to 3rd gear in some instances on steeper descents. If you wanted to come up one gear at a time you can move the shifter from D to 4 back to D. If for some reason you wanted to go to full coasting (5th gear not in fuel cut) move the shifter from D to N back to D.
    TnShooter and Dm93 like this.
  6. May 1, 2024 at 7:19 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    If you use your brakes for 100% of the downhill speed regulation, it’s almost certain the rotors will warp. Some vehicles are worse about this than others, and as the Tacoma by all accounts has merely adequate brakes, it is very likely to happen.
    wilcam47 likes this.
  7. May 1, 2024 at 5:52 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You aren't hurting the transmission in the least. Not downshifting will eat up your brakes a lot sooner and possible lead to brake failure in a bad place.
    My truck has the feature, but I never notice it. I always manually downshift way before the truck does and I downshift to lower gears than the truck does. You do have to use some common sense. You don't wait until the truck is doing 50 mph then drop it into 2nd gear. Doing that could well break something. I also manually downshift going up hills to keep engine rpm's in the best range for power. The truck will eventually downshift, but it only does it AFTER the engine is struggling. It's better to do it BEFORE the engine starts to struggle.
  8. May 1, 2024 at 5:59 PM
    Wahayes
    Wahayes Well-Known Member
    Will
    2017 tundra (sold) 2015 tacoma trd 1984 c10
    What all the others said. There's a reason that big rigs use engine braking and downshifting to navigate the mountain passes and not brakes. When I go over donner pass in california , I don't ever even use the brake pedal (I'm a cdl driver)
  9. May 1, 2024 at 6:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The transmission will be fine. If it was that brittle it would be breaking just trying to move the truck up the hill
