I dropped my 2001 tacoma truck back off at the dealers this morning
Discussion in '1st Gen. Tacomas (1995-2004)' started by steves01, Jan 15, 2012.
  1. Jan 15, 2012 at 8:03 AM
    steves01
    steves01 [OP] Active Member
    Tacoma, dbl, cab, 4x4, v6
    N/A
    After frame replacement problems.....I dropped my 2001 tacoma truck back off at the dealers this morning and got a phone call telling me later in the day that they cant align the bed according to the service writer. Then a call laterfrom the service manager said the truck has allowable variances in gaps and that he wont do anything on the truck untill the FSM rep from toyota pooks at it on the 24 january. This rep I'm sure is just another good ol boys in the dealers chain of command so I called in a case to toyota corp also.
  2. Jan 15, 2012 at 8:04 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Huh.
    So what do you suggest be done?
  3. Jan 15, 2012 at 8:09 AM
    steves01
    N/A
    Fix the bed if thats what is wrong. This truck has had lots of problems since it came back from the dealer. One of them was fixed by pullin the bottom of the front brake dust shields up.
  4. Jan 15, 2012 at 8:12 AM
    babytruck
    NorCal
    They are saying that the variances are allowed? Is it a danger? Perhaps when they put on the frame things were not adjusted around it? Such as the brake shields?
  5. Jan 15, 2012 at 8:20 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Got any pics of this? I would agree with the guy that small variances are normal, but if it's like the box is rubbing the cab that's bad.
  6. Jan 15, 2012 at 8:30 AM
    steves01
    N/A
    I can slip my fingers in between the cab bed on one side and cant on the other. They shimmed the left side of the bed and it looks good but did not readjust the bumper. I didnt think shims would be needed on a bed?
  7. Jan 15, 2012 at 8:32 AM
    babytruck
    NorCal
    Oh that's bad. I wonder if you can take it to another dealer to have it adjusted, you know - in a second opinion sort of way.
  8. Jan 15, 2012 at 8:34 AM
    steves01
    N/A
    Thats what I think should happen...A second opinion
  9. Jan 15, 2012 at 8:38 AM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    The Toyota rep that comes out is actually from Toyota and does not work for the dealership at all. Everytime there is a rep from Toyota that comes to my job its always a different one and nobody has seen them before. Weird the way it works.
  10. Jan 15, 2012 at 8:56 AM
    babytruck
    NorCal
    What other problems have happened since the new frame? And do you have your truck now or is it still at the dealer?
  11. Jan 15, 2012 at 9:11 AM
    steves01
    N/A
    Missing bolts, nut loose hose on PS pump. Scratches they didnt fix and light out on the dash that worked befor they did the frame. The rubber inner fender shields were ripped up and tossed back on that way.
  12. Jan 15, 2012 at 9:12 AM
    steves01
    N/A
    I'm gald the rep is not a good ol boy!
  13. Jan 15, 2012 at 9:14 AM
    canadian tacokid
    canadian tacokid Member
    nova scotia
    2001 4x4 v6 5 speed taco
    stock, just got brand new frame from from dealership, 277k miles still running strong
    my frame was replaced in 2010, got the shop to put in a new front diff the other day, they said whoever did the frame overtourqed 4 of the kframe bushings by 40 pounds he had to replace them and did it free of charge, love the trucks dislike dealers.
  14. Jan 15, 2012 at 9:16 AM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Sounds to me like they put a used frame in that was already bent. I think u got the bone dude.
  15. Jan 15, 2012 at 9:18 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    You need to go to the dealership and raise hell. This is just bad work done by the technicians. I do not know if the FSM can help you, as each dealership is privately owned.
    I had a problem with a dealership service and got the FSM involved, it did not get anything resolved. Your case may be different. In hind sight, I should have threaten the dealership with a court case, maybe it would have got the issue resolved.
  16. Jan 15, 2012 at 9:18 AM
    steves01
    N/A
    I'm not to crazy about this dealer, I've been back 4-5 times after frame replacement. That was one of my questions..Is it the dealers problem or the Toyota corp?
  17. Jan 15, 2012 at 9:27 AM
    dauange
    dauange Well-Known Member
    Central Ohio
    '01 PreRunner, Dbl Cab, 4 cyl
    I had a lot of issues with mine too. After a lot of arguing, my dealer and the Factory Service Rep determined that the new frame was defective. The issue was that where the leaf spring shackle mounts were welded on the new frame. The body shop was the one that finally determined this to be the issue. Seems that it is only an issue with the double cabs and not any of the other frames. They put a second new frame on mine (without confirming that it was constructed properly) and it was the same as the previous. The end result was that Toyota Corporate instructed the dealership to shim the bed so that it was closer to being level and to rotate the bed so that there was closer to equal spacing on each side between the bed and the cab. I fought and fought with Toyota Corporate that it should be fixed properly and not half assed. Never got anywhere with them and gave up. Hope that you have better luck than I did.
  18. Jan 15, 2012 at 9:32 AM
    babytruck
    NorCal
    Oh my. So he may have gotten a bad frame then. :(
  19. Jan 15, 2012 at 9:35 AM
    dauange
    Central Ohio
    Sounds that way but this was fall/winter of 2010. That means that Toyota has known for well over a year that Dana is continuing to build some replacement frames for double cabs incorrectly.
  20. Jan 15, 2012 at 9:36 AM
    babytruck
    NorCal
    Well I guess we will have to see what the rep says. But in the meanwhile, I'd do some googling to see if this is an ongoing issue, copy the complaints and bring it with you if you go to meet the rep. Also, I'd call corporate to let them know what is going on so you can start a file.
