I Dunno what to do with my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Grande, Aug 4, 2010.
  1. Aug 4, 2010 at 11:55 AM
    Grande
    Grande [OP] Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    well i was gona get a spindle lift for my truck, but it kinda seems like it would take a way some performance bcuz of the height, then i would get bigger wheels and tires, and that kills performance. So i was thining about spacers to level out the truck so i could keep my stock wheels and throw some all terrains on there, i kno theres coilovers and stuff but if u crank it up wont the ride be bumpy and ruff. Im confuse on what to do. Maybe i should just keep it stock....no never mind, scrap the whole stock part, lol. i should just brainstorm a lil more b4 i decide what to do.
  2. Aug 4, 2010 at 12:00 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Go to Toytec and look into a suspension lift. I got mine for around $500 shipped to my house. I then installed it myself. You will then be able to fit 33's with slight trimming, you could use a razor knife. With my lift and tires I have made up to 19mpg. However I wheel and drive without concern for fuel and thus I don't make the mpg that I can when I drive conservatively.
  3. Aug 4, 2010 at 12:01 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    New coilovers will ride better than spacers, and spindles will ride same as stock, obviously.
    Spindles are not cheap. What's your budget?
  4. Aug 4, 2010 at 12:01 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    What do you plan to use your truck for? Off-roading, Street driving?
  5. Aug 4, 2010 at 12:02 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i used the OME kit. DIY install. leveled it out, with a mild, very mild lift at both ends. 884 springs in the front, and 1.5" AAL in the back.
    stock tires, stock rims.
  6. Aug 4, 2010 at 9:48 PM
    Grande
    Victorville, CA
    I have like 3k to play with but dunno if I wana spend it all, I think I might get the coilovers with some bigger tires might get a set of wheels too......
    I plan on everyday driving but I also love taking trails and fireroads around the mtns where I live, but no crazy hillclimbs or rockcrawling, so there would be a lot of off roading on the weekends and stuff.
  7. Aug 4, 2010 at 9:48 PM
    Grande
    Victorville, CA
