I effed up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CenTexasTaco, Apr 16, 2015.
  1. Apr 16, 2015 at 6:56 AM
    CenTexasTaco
    CenTexasTaco [OP] Well-Known Member
    Grayson
    Atlanta, and a ranch way out in Texas away from al
    2011 red sr5
    Changed out my pads and rotors and figured I'd change my break fluid and now iv got no brakes at all. I know it's most likely air in the line and my calipers not putting pressure on the pads. What's gonna be the best way to fix this bitch
  2. Apr 16, 2015 at 6:58 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Bleed the brakes, you have the answer right there in your post.
  3. Apr 16, 2015 at 7:00 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  4. Apr 16, 2015 at 7:04 AM
    CenTexasTaco
    Grayson
    2011 red sr5
    I bled them last night and lost my rear breaks as well as the fronts. How many times should I have to do it ?
  5. Apr 16, 2015 at 7:06 AM
    Gearheadesw
    Davenport Fl
    Until all the air is out. Make sure you don't suck the master cylinder dry while bleeding, right back to square one.
  6. Apr 16, 2015 at 7:07 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    If done correctly you only need to do it once.
  7. Apr 16, 2015 at 7:08 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
  8. Apr 16, 2015 at 7:11 AM
    Gearheadesw
    Davenport Fl
  9. Apr 16, 2015 at 7:14 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Get a vacuum brake bleeder, and you can do this job as a one man. Start at the wheel furthest from the MC and work to the closest. A quart should probably do...
    Howard
  10. Apr 16, 2015 at 7:14 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Only once? But seriously, take your time and do not let the reservoir get close to empty. There are several types of kits to make it a one-man job.
    It only takes a small bubble to absorb the pressure.
  11. Apr 16, 2015 at 7:19 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Bleed of ABS system is tricky if you dont have computer.
    What you need is to find spot with slippery surface (Snow, Grass, Gravel)
    Get some speed and hammer brakes until ABS kicks in.
    That should bleed valve inside the ABS unit.
    You may have to do lines again afterwards.
    Order (It goes from Shortest to longest line. because you dont want to push air to longest line while bleeding short one, so always start with shortest and do longest lines last)
    1. Front Pass side
    2. Front Driver side
    3. Rear Driver side
    4. Rear Pass side.
    Here is a procedure from FSM ...
  12. Apr 16, 2015 at 7:52 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    :thumbsup:
    +1
  13. Apr 16, 2015 at 7:59 AM
    CenTexasTaco
    Grayson
    2011 red sr5
    allright guy thanks im gonna try this again after class and get it straightened out
  14. Apr 16, 2015 at 3:55 PM
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    Are you using a siphon? or a one way check valve?
    I've had check valves that leaked and allowed air back in before, only reason I ask.
  15. Apr 17, 2015 at 7:49 AM
    CenTexasTaco
    Grayson
    2011 red sr5
    All is good there was a whole lotta air in it
  16. Apr 17, 2015 at 10:09 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Nice!
  17. Apr 17, 2015 at 10:22 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if only you had a TRD OR 4x4 with atrac.... bleeding brakes is about the easiest thing ever thanks to the electric accumulator pump... it will literally bleed a fully dry line in 30 seconds for you with one long push of the pedal.
    that stated i always thought it was longest line first. either way if you got a good amount of air in the system especially with the separate ABS unit found on your truck its gonna be kind of a pain to get it all out.
