I F*CKED up bad. Need HELP PLEASE.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Handofdoom, Feb 16, 2012.
  1. Feb 16, 2012 at 1:30 PM
    Handofdoom
    Handofdoom [OP] 49er Faithful
    Nathan
    Rohnert Park, CA
    2011 Taco TRD 4x4 Acs. Red
    flowmaster series 50 muffler, trd skidplate, sockmonkey trd sticker, elusive elements light bar, HID Kragen 7" lights behind grill, Grillcraft mesh Black top and bottom, Zombie Light switch.
    ok so i was doing the fog light mod and I screwed up i cut the green wire on accident but I was able to connect it back together and hook up the new wire for the relay. Anyways it was working fine and today i am in the in and out drive thru and my radio just turns off next thing I know my abs light is on and so is my emergency brake. So when i get home i turn off the truck and try to start it again it doesnt start!! it just clicks over and over again. like the starter isnt working or something. I check the wire and see that it came apart so what I did was remove all the new wire and rebent the relay so it would be like it was stock. I reconnected the green wire really good this time and made sure it wouldnt come undone. truck still wont start just clicks, clicks, clicks, but the radio and everything else seems to be working again but truck wont start!!! need help please. I am a retard!!!!
  2. Feb 16, 2012 at 1:32 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    check all your fuses
  3. Feb 16, 2012 at 1:35 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Disconnect the neg terminal on the battery for 5 minutes and then try again.
    Also, whenever you work on any wiring, always disconnect battery first.
  4. Feb 16, 2012 at 1:38 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    aww man, good luck. This is why I'm so damn scared to mess with anything electrical on my truck...
  5. Feb 16, 2012 at 1:39 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    post a pic of your work...maybe i can figure out what happened...
    also check all ECU fuses because if one goes out...the ECU trips and starts lighting up stuff that is working :p
  6. Feb 16, 2012 at 1:45 PM
    Handofdoom
    Nathan
    Rohnert Park, CA
    I just checked all fuses them seem to be fine. one hade what looked to be burn marks on it but the insides were fine. It seems like it wanted to crank over and then more clicking. I just disconnected the battery i will try again in five minutes.
  7. Feb 16, 2012 at 1:46 PM
    badger
    badger Well-Known Member
    07 SR5
    You are assuming one caused the other. Maybe, maybe not. If I just heard about the symptoms I would say your charging system is at fault, and your battery is dead. Do the cable disconnect as suggested. If it's still dead, pull the battery and check it, and/or charge it. If the battery was dead, it's most likely a charging issue. That is sure what it sounds like to me.
  8. Feb 16, 2012 at 1:48 PM
    UH60Hwkdrvr
    UH60Hwkdrvr Well-Known Member
    El Paso, TX
    2023 Tacoma Limited Nightshade 4x4
    ^^ This.
    M.A.C.
  9. Feb 16, 2012 at 1:51 PM
    Handofdoom
    Nathan
    Rohnert Park, CA
    I thought it was the battery too. i just dont have anybody around to give me a jump.
  10. Feb 16, 2012 at 1:51 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    sounds like something shorted out and drained your battery. try charging it after you get everything hooked up again
  11. Feb 16, 2012 at 1:53 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... ^^^ ... Ditto ... "electrical cooties" ... :confused: ... will get in your truck, if you are not super careful ... :eek:
  12. Feb 16, 2012 at 1:55 PM
    jrider636
    jrider636 Well-Known Member
    justin
    tally,fl
    08 tacoma prerunner
    surely the battery isnt the source. its a 2011. but hell u never know. always cover the basics
  13. Feb 16, 2012 at 1:56 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    it could be if something shorted and is slowly draining the battery
  14. Feb 16, 2012 at 1:59 PM
    badger
    07 SR5
    A jump won't fix anything. If it's dead, your charging system is the reason. You were driving the truck when all this happened so it's not just a run down battery. A jump only works if the charging system is good and the battery is run down.
    Do what I described. Cable pull first, then pull the battery or diconnect both cables to charge it in the truck. I prefer to pull batteries out to charge them just in case it blows. It's just a good practice :D
  15. Feb 16, 2012 at 1:59 PM
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    Sounds like you have something shorting out, or a bad ground. Please check and double check everything you touched wiring wise ASAP.
  16. Feb 16, 2012 at 2:00 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I think you drained the battery. Use a multimeter and test the battery voltage. Just because accessories work doesn't mean that your battery has enough juice to start the truck.
  17. Feb 16, 2012 at 2:08 PM
    badger
    07 SR5
    He had enough juice to start the truck and he was driving it when it started going down. If the charging system were working and it was just a drained battery, it would have recharged. He could have caused some weird condition, but if the batttery is dead it is either the charging system or a completely shorted (internally) battery (not that likely IMO).
  18. Feb 16, 2012 at 2:17 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    First, undo everything that you did. Then read these links:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/33318-halp.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/114423-bad-news.html
    and I agree with the battery and charging system.... Pull the battery, charge it up outside of the truck, meter it, and then check it with a meter 30 mins after you charge it... If the voltage isn't the same (or at least very similar), you've got a battery issue.
    If you've got a dmm with an amperage meter in it, you can always hook up the meter to the positive terminal and to the positive clamp (as in an in-line setup) and see if you've got a drain on the system.
  19. Feb 16, 2012 at 2:21 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    if that green wire stopped the charging system from getting power back to the batt he could have just been running off the battery, which could be why it is not starting now
  20. Feb 16, 2012 at 2:23 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Sounds like a drained battery to me.
