I F*CKED up bad. Need HELP PLEASE.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Handofdoom, Feb 16, 2012.
  1. Feb 16, 2012 at 2:23 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    oh and OP how did you reattach the green wire? id recommend a solder and some heat shrink tubing. Test the batt first before you worry yourself to death
  2. Feb 16, 2012 at 2:25 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Sounds like the battery is dead. When you say that you reconnected the wire real good ... I'm hoping that means you soldered it?
  3. Feb 16, 2012 at 2:27 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I lost track when you mentioned In N Out... :eek:
  4. Feb 16, 2012 at 2:51 PM
    Handofdoom
    Handofdoom [OP] 49er Faithful
    Nathan
    Rohnert Park, CA
    2011 Taco TRD 4x4 Acs. Red
    flowmaster series 50 muffler, trd skidplate, sockmonkey trd sticker, elusive elements light bar, HID Kragen 7" lights behind grill, Grillcraft mesh Black top and bottom, Zombie Light switch.
    ok so my buddy came over we hooked up his car and waited about a minute and the truck turned right over and is running fine no abs light or emergency brake light. I am about to go take it on a drive so i can get a soldering gun from walmart and put it back together the right way. thanks for all your help. :rolleyes: This may be my last mod. side not I took out everything I did and returned it to stock I am done with this mod nonsense. until i get my 7" hid from the gb that is hehehehe:)
  5. Feb 16, 2012 at 3:10 PM
    99TRD
    99TRD Well-Known Member
    17 Tacoma TRD OR DC Auto V6
    Smoke headlights, improved LED tail lights...Pending: De-chrome badges and grille, new tires
    My battery died a few months ago and my truck did weird things too. They were weird enough that I wasn't entirely sure it was the battery, but common sense led me there. Replaced it with a good Interstate and all issues were cleared up.
  6. Feb 16, 2012 at 3:32 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    When your battery is dying due to not charging properly, before the truck dies, different lights will illuminate on the dash as things like your abs, airbags, etc utilize power from the battery directly, so when it goes, these systems will alert you to the fact that they cannot function properly. Chances are, you may have a few codes stored showing the fact that these vehicle systems had lost connection to ECU or that they simply had low voltage to use.
  7. Feb 16, 2012 at 7:43 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Put everything back to stock.
    Check all the fuses. Especially the one with the black marks on it. That does not sound right.
    Charge/test the battery.
    I think the wire you cut may have been needed for battery charging.
  8. Feb 16, 2012 at 7:54 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    So it did end up being the battery and such. I thought it was because he used the hand of doom.
  9. Feb 16, 2012 at 8:15 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    That part of the thrill of doing mods. When I did my inverter ac outlet in cab i connected the wires wrong. Started didnt work. Another 2 hours to reattach what i had taken appart to drive home, was in my warehouse. Came back the next day, restarted the process and got everything working easily.
    Everyone who has done a decent amount of mods has royaly fucked up at some point.
  10. Feb 16, 2012 at 8:24 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    I loled
    :rofl:
  11. Feb 16, 2012 at 8:33 PM
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    Its a big difference when its close to or straight up paid off vsmaking payments on a newer truck, no?
  12. Feb 16, 2012 at 8:38 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    What does that have to do with it? The manufacture year has no bearing on a drained battery.
  13. Feb 16, 2012 at 8:39 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    You have to make mistakes to learn. Modding your truck just helps to make less of them.
  14. Feb 16, 2012 at 8:53 PM
    medic2230
    Murph
    Bama! Roll Tide
    no, mod that bitch! :)
  15. Feb 16, 2012 at 8:53 PM
    #35
    stewartx
    Huntsville AL
    Not necessarily, badger. He could be driving relatively short distances which doesn't allow the battery to fully recharge, with the cumulative effect over time being a dead battery. That could be compounded by a charging system already strained by multiple installed accessories.
    I agree with the others. As a first step, he should check his recent wiring mods, jump start the vehicle, and then take a long drive to fully charge the battery. If that solves the problem, no need to go further. However, if the problem persists, he can then focus on other possibilities.
  16. Feb 16, 2012 at 9:10 PM
    #36
    TACWUT
    San Diego
    12 prerunner DC
    I havent even made my first payment and have my ride pretty far ahead lol. Just saying not everyone has a huge cash flow.
  17. Feb 16, 2012 at 9:26 PM
    #37
    stewartx
    Huntsville AL
    Mine is only two months old and is an ongoing work of art. Last month, it was side steps, bed toolbox, electronic tailgate lock, and similar. This weekend, it's a winch on the front and loading off-road equipment & tools into that toolbox. Next weekend, it's a CB radio setup. After that, I'm thinking about a hot tub or swiming pool for the bed. :eek: :rofl:
  18. Feb 16, 2012 at 9:50 PM
    #38
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    You need a new battery. You ran it down. I did EXACTLY the same thing on this. I made a thread on it if you go through my profile and find it
  19. Feb 16, 2012 at 9:57 PM
    #39
    badger
    badger Well-Known Member
    07 SR5
    How much you want to bet he's sitting at Walmart now and his truck won't start? :D
    OP's Quote: " Anyways it was working fine and today i am in the in and out drive thru and my radio just turns off next thing I know my abs light is on and so is my emergency brake."
    That will not happen because of a dead battery when you have been driving and you are sitting with the engine running. The alternator produces enough current to both charge the battery and run the engine. What he described only happems when the charging system is not working.
    His buddy came over and they left his car attached for a few minutes so he probably had enough charge to get down the road a ways. I hope he took his cellphone :rolleyes:
  20. Feb 16, 2012 at 10:02 PM
    #40
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    wow those links made my day. 1st one quite possibly the best thread ever.
