I FINALLY FOUND THE HUMMING NOISE ON 2014 SPORT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saltair, Dec 9, 2014.
  1. Dec 9, 2014 at 6:15 AM
    saltair
    saltair [OP] Member
    Tacoma Sport
    I don't think this has been posted before. Just an FYI.
    I occasionally heard a humming noise in my garage that I could not find. I finally leaned over in the bed of my 2014 Sport TRD and heard the hum. I slid under the truck and found the noise coming from the gas tank and could feel the electrical wires above the tank vibrating. I called the local Toyota dealer and the repair rep. said it was a "self check" designed to pressurize the gas tank and check for fuel system leaks. This self check probably lasted close to 10 minutes and I'm not sure how often this test occurs.
  2. Dec 9, 2014 at 7:00 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Yeah its been posted. Glad you figured it out tho.
  3. Dec 9, 2014 at 7:03 AM
    Roundarc
    Roundarc Born again Tacoma Owner
    Allan
    Virginia
    2025 TRD Sport Premium
    That's just your trunk monkey reminding you to feed him....
    http://youtu.be/8avOiTUcD4Y
