I fixed my rusted frame, and video-taped it all
Discussion in '1st Gen. Tacomas (1995-2004)' started by seymourless, Jul 20, 2016.
  1. Jul 20, 2016 at 8:42 AM
    seymourless
    seymourless [OP] Well-Known Member
    Hey everyone,
    First off, thanks to all who posted on the forums and documented how they fixed their rusty frames, specifically the ones that were rusted through near the leaf springs. It gave me the confidence to try and tackle the job on my own.
    For background, I bought my tacoma not knowing how bad the rust was, due to the previous owner covering up the frame with bondo and house putty. I was pissed. I got a very good deal on the truck considering it only has 140k, so you win some/lose some.
    Feel free to ask any questions you may have!
    Part 1: https://www.youtube.com/watch?v=AsQRBHy5RPc
    Part 2: https://www.youtube.com/watch?v=XB6mzShuts8
    These are the parts I purchased, minus cutoff off discs out the wazoo:
    Auto Rust Solutions
    Quantity(1) # ART-083-S Safe-T-Cap, Rear Forward Spring Area, Toyota Tacoma
    Eastwood
    Quanitity(2) # 12515Z: Internal Frame Coating 14 oz w/Spray
    Quanitity(5) # 16060Z: Eastwood Rust Encapsulator Black Aerosol
    Quanitity(1) # 13651Z EW Rubberized Rust Encapsulator Blk Aero
    Low Range Off-Road
    Quantity(1) TSP-WLH Rear Spring Hanger Kit, Welded (comes with both sides)
    Wheelers Off-Road
    -Old Man Emu(OME)
    Quantity(1) OME GS12 Greasable Shackle Kit
    -Daystar:
    Quantity(1) DAY KT02017 Greasable Bushing Kit
    Quantity(4) Tacoma Poly Spring Eye Bushing
    Quantity(4) Tacoma Shackle/Frame Bushing, for GS12 & Factory Shackles
    -Wheelers Off-Road Brand
    Quantity(1) WHE U6754X U-Bolt Set, (4) U-Bolts w/Hi-Nuts and Washers, 6.75"
    01iver123, tomwil, vtframer and 9 others like this.
  2. Jul 20, 2016 at 8:52 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I don't have any rust issues on my 1998 Tacoma so I didn't look at your videos; however, from the preview images that you posted it looks like you did a helluva good job fixing the rusted-out areas. Hopefully you'll get your money back, and more...;)
  3. Jul 20, 2016 at 9:02 AM
    Tcoma16
    Tcoma16 Well-Known Member
    California
    2016 TRD Sport
    Great videos Brother! The finished product looks great! Thanks for sharing. :thumbsup:
  4. Dec 27, 2016 at 8:30 AM
    Sonam
    Sonam Active Member
    2002 Tacoma Xtracab SR5 4WD
    Found your videos on YouTube first and just saw this post here. My Tacoma doesn't have any frame rot, but had significant surface rust on the frame and lots of flakes/chips of rust on the rear differential and some other parts. I spent a long, long time and a huge amount of work (probably a month and a half of work, a few hours here and there and a bunch of days of 4-6 hours of work). I worked only from the underside, grinding, chiseling, sanding, wire wheel brushing, wire brushing. That was the hardest part. Then, I applied 4 coats of Rust Mort on those spots, some spots I would re-grind, chisel, sand, then reapply a coat or two of Rust Mort. Then I applied some self-etching primer that contains some phosphoric acid to create more rust conversion in case I missed some spots with the Rust Mort. 2 coats on most spots, then 2 coats of truck bed liner on the whole frame, differential, skid plates, and other parts. I still have one spot to touch up/redo that is only primed. I did it all in sections, since I didn't have the opportunity to have another vehicle to drive - so when I ran out of day light, I would drive around and do what I needed to do all the way up until the first snow of the year. The extreme drought conditions here certainly helped the process for keeping things clean/dry while I did this long term work.
    I have a rust hole in the bed and on a side panel, but just picked up a used bed from someone on the forums here. So in the Spring/Summer, I plan on finishing the frame project by removing the bed, as done in these videos, so I can address the top parts that I couldn't access from the underside. Then I repair the bed and put it back on - something like that. It is going to be so nice and shiny.
    Thanks for the videos. I would say these videos were most informative and important for giving me enough motivation to tackle this kind of project.
    seymourless[OP] likes this.
  5. Dec 27, 2016 at 8:44 AM
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    When you said video taped I'm sitting here imagining you setting up an old school recorder that takes full size VHS tapes and going in and popping it in the VCR lol. For this of you who are to young to know what either of those are it's probably your nap time hahahaha
    rodehard, bry838 and Sonam like this.
  6. Dec 28, 2016 at 11:03 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Well done. Appreciate the effort and time put into this video. Another Tacoma saved from the scrap heap!
  7. Dec 29, 2016 at 7:55 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Great videos!! My frame is not as bad as yours was but I will need to do some similar work.
  8. Dec 30, 2016 at 7:25 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    that looks like an 01-04 truck so why didn't you just get your free rust out replacement frame done through Toyota?
  9. Dec 30, 2016 at 2:03 PM
    ClevSix
    IL/IA
    If the PO didn't get it inspected and treated by Toyota then it is no longer covered under the frame replacement program.
  10. Dec 30, 2016 at 2:11 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Well, if you ever run for President I'm voting for you. Well done
  11. Jan 4, 2017 at 1:32 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Nice ! I have a 2003 Taco. How do you plan to limit the inside of the frame from rusting ?
    I'd like to take the bed off mine this summer too.
    I also have a stock " hole" in the frame just behind the front wheels. Seems like a lot of salt/road debris would get in there ? I use the hole at the car wash to spray the frame out. I may try and make a designer spray shield with an old semi truck mud flap or thin aluminium.
    I had a crazy thought. Seal all the holes in the frame. Connect an electric vacuum pump to the frame. (Water can't live in a vacuum) It would have to be a separate vacuum source than the engine, so if a leak developed it wouldn't throw off the manifold vacuum. Thoughts ???
  12. Jan 5, 2017 at 6:46 PM
    ClevSix
    IL/IA
    Your Vacuum seal idea would be exceedingly difficult.
  13. Apr 14, 2017 at 6:07 AM
    vtframer
    vtframer Well-Known Member
    Vermont
    2001 Tacoma SR5 Extended Cab, 4x4 Manual Trans.
    seymourless - where did you truck live it's life? was is ever under-coated? nice job on the repair!!
  14. Apr 25, 2017 at 10:58 AM
    seymourless
    Hey! it spent the first 2 years in New Hampshire, then the rest of its life in Virginia.
