I fixed overhead console compas/thermo, second time, need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeper2269, Oct 30, 2010.
  1. Oct 30, 2010 at 8:45 PM
    jeeper2269
    jeeper2269 [OP] Well-Known Member
    I fixed the compas overhead console temp last week, and my dome light, and lights on the console its self wont work now. I checked all the fuses twice, and nothing is blown.
    I fixed the compas/temp gage before with no problem. all is same
    any ideas?
  2. Oct 30, 2010 at 9:36 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Mine just went out again too! WTF!? Bump for you, I can check into it tomorrow when I tear into mine
  3. Oct 30, 2010 at 10:47 PM
    jeeper2269
    so. I put all the wires back in place, and the same results. the dome light dont work, and the clock under the head unit cd player stays at 0100 to start every time. wtf? did i do?
  4. Oct 31, 2010 at 3:08 PM
    jeeper2269
  5. Nov 1, 2010 at 5:59 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Check the voltage at the dome light to see if it's no power vs. bad bulb. Sounds like there is no constant 12 volts going to your radio clock and dome light. Check the voltage at the fuse block instead of visual inspection. Your radio needs constant 12v for it to keep the clock and radio stations. Right now it resets everytime you turn off/on the ignition. My guess is no 12v at fuse block at the dome light location. Double check the fuse and check voltage with it plug in.
  6. Nov 2, 2010 at 9:19 PM
    jeeper2269
    But why in the heck would fixing the overhead compas affect the dome light and clock?
  7. Nov 3, 2010 at 3:45 AM
    Wattapunk
    Uncle K
    TX
    Unless you d/c the battery during repair, my guess is a wire got accidently grounded and shorted the dome power supply. The compass/dome are supplied with 12v. Just a guess..
