I fixed the vibrations from my subwoofer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ultima GTR Guy, Oct 5, 2008.
  1. Oct 5, 2008 at 12:42 PM
    Ultima GTR Guy
    Ultima GTR Guy [OP] Active Member
    Carlsbad, CA
    09 Double Cab Short Bed TRD Sport
    When I listened to certain music the subwoofer would vibrate the plastic enclosure and the plastic covering behind the rear seats. I removed the removed the plastic panel behind the driver (3 bolts), then the rear seats (6 bolts) and then the large panel passenger's side (1 bolt). This fully exposed the subwoofer cabinet and amplifier. I removed the Subwoofer (5 bolts) and used Fat Mat to coat it everywhere I could. Then I coated the backs of the 2 panels already removed with as much Fat Mat as I could. Then I put it back in the reverse order and it works and sounds so much better. It sounds solid to much higher outputs than it would before.
    Hope that helps someone else tame their sub.
    Paul
  2. Dec 10, 2008 at 6:02 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Yeah Paul this helps. I notice some localized vibration around my sub only on certain bass notes (high ones), otherwise it sounds great. I'll have to try some insulation.
  3. Dec 10, 2008 at 6:08 PM
    TommyTaco09
    TommyTaco09 Well-Known Member
    San Diego
    2009 TRD DC Pyrite Mica
    Tint: 20%F 35%R
  4. Dec 10, 2008 at 7:12 PM
    nvdeserted
    Reno, NV
    Thanks man. I read that one earlier. I found that everything sounds good except for some of my burned CDs, which is typical. My ipod sounds great over the system. Plus, the high bass notes just started this vibration which leads me to believe that a gap has occured over the last couple of weeks rocking hard.
  5. Dec 11, 2008 at 10:38 AM
    TommyTaco09
    San Diego
    Tint: 20%F 35%R
    You have the JBL system right? I noticed too that as the weeks past by I heard more interference. Imo, I would still take it in because now it's a well known prob that toyota has no problem fixing. Also the new amp they installed in my truck yesterday kicks a$$. It bumps harder and overall quality is phenomenal!
  6. Dec 11, 2008 at 1:15 PM
    nvdeserted
    Reno, NV
    In that case I'll head to the dealer if there is a quality improvement to be had. Should I just show up with a frown on my face, or is there some leverage I can print out and bring along?
    Thanks
  7. Dec 11, 2008 at 2:22 PM
    TommyTaco09
    San Diego
    Tint: 20%F 35%R
    Take in the a print copy of the other thread and this JBL-Toyota promise: http://www.jbltoyota.com/toyota_taco...advantages.asp
    They shouldn't give you any trouble as long as you can reproduce the problem.
    Some dealers that have done the amp replacement
    http://www.sunrisetoyota.com/
    The Service Manage: Bob Morano
    My Toyota Dealer is:
    http://kmtoyota.com/
    The Service Manager: Scott Buckner
    8582798151 x1300
    Hope this help brotha!
  8. Dec 11, 2008 at 10:38 PM
    nvdeserted
    Reno, NV
    Really, I'm pretty happy with mine. It is kinda weird though: the woofer seems to top out around 40 and has the same output at 60 that it did at 40, but the other speakers progressively get louder all the way up. I am a little disappointed that I'm hearing something vibrating around the sub (sounds like plastic on plastic) already, considering the truck has less than 1k on it. Hopefully the replacement amp and some insulation will end any secondary sounds.
    I too laughed at the sight of the woofer the first time I saw it, with the little blue light on it, but now it's grown on me and I think it is pretty cool. Sorta strange that the light is blue, considering that it is the only blue thing on my truck...
    Oh, and I have to get a new stereo too. My volume and tuner knobs periodically don't work?!!
    As for the automatic volume changing, make sure to set VSM (or something like that in the menu) to OFF, it's something that is designed to increase the volume the faster you go, quietest when stopped.
  9. Dec 16, 2008 at 3:27 PM
    nvdeserted
    Reno, NV
    So I got the ball rolling at my dealer regarding the new amp. After messing with the stereo, fading completely to just the rear speakers, I did notice that the 2 smaller speakers do sound "scratchy" compared to the front 2, and something is still vibrating near the woofer. Luckily I had enough information from this forum to dispell any theorys the service guys could think of and just get to the point of getting in the new amp to see if it in fact corrects the problems.
    They are going to "take a look" tomorrow morning when their rep is in, and then hopefully order the new amp. Luckily my salesman previously worked in car audio, so he's pushing for the new amp too. Fingers crossed.
