I FOUND BRAKES ON CRAIGSLIST, I NEED EXPERT EYES & OPINIONS
Discussion in '1st Gen. Tacomas (1995-2004)' started by The_Sahara_Man_FJ80, Sep 30, 2017.
  1. Sep 30, 2017 at 7:55 PM
    The_Sahara_Man_FJ80
    The_Sahara_Man_FJ80 [OP] Never Settled
    Ish
    NorCal; Santa Cruz <—> SF <—> Lake Tahoe
    2004 2.7l Tacoma 4WD
    -- OME Dakar Leafs -- ToyTec adjustable shackles —allpro armor— -- Bilstein 5100s all around -- Toytec Coils -- Ebay UCAs w Allpro Uniballs --Toyota bug/wind deflector -- Weld Racing Scorpios -- SnugTop Hi-Liner — BedRug Bedliner --Spyder LED Tails -- Black Horse taillight guards --33"Cooper STT Pros -- 800w Quad row spot/flood LED bar -- Uniden Bearcat CB -- Firestik 5ft antenna -- K&N CAI
  2. Sep 30, 2017 at 8:01 PM
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    The rear brakes on Tacomas are drums, unless you have the rear disc brake conversion on your truck.
  3. Sep 30, 2017 at 8:02 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    those aren't for your tacoma
  4. Sep 30, 2017 at 8:03 PM
    The_Sahara_Man_FJ80
    Ish
    I knew I had drums in the back, was planning on doing the fronts
    but they would still fit, i'd like to guess
  5. Sep 30, 2017 at 8:07 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nope. Dead giveaway is that they have the wheel studs pressed into them and Tacoma rotors have holes for the studs that are pressed into the hubs to slide through.
  6. Sep 30, 2017 at 8:08 PM
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
  7. Sep 30, 2017 at 8:11 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you're going to spend that kind of money, get a first gen Tundra big brake upgrade:
  8. Sep 30, 2017 at 8:17 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    This.
    I'm planning on doing this as well. If decide to do this I can probably lend a hand given we have shared available times.
  9. Sep 30, 2017 at 8:21 PM
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
    Do they have something like this for second gens?
  10. Sep 30, 2017 at 8:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I don't think that the bolt holes line up and the Tundra brakes aren't much larger than the 2nd gen's anyway. The biggest upgrade I got for my 2nd gen were stainless steel brake lines that made more of a difference in braking feel than new pads and rotors (Hawk HPS and Brembo).
  11. Sep 30, 2017 at 8:30 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    the 2nd Gen Tacoma already has the bigger rotors/calipers
    02YotaGuy[QUOTED] likes this.
  12. Sep 30, 2017 at 8:39 PM
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
    I need to get longer lines and upgrade to steel. I had steel lines on my BMW and it made a big difference.
    Dalandser[QUOTED] likes this.
  13. Sep 30, 2017 at 8:44 PM
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
    Maybe mine just need to be rebuilt, but they seem really weak.
  14. Sep 30, 2017 at 8:55 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Try some new brake lines before you do anything else and see what you think then...
  15. Sep 30, 2017 at 8:56 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    rotor/pad type make a difference too. but yeah, steel lines will give you the best stopping power
  16. Sep 30, 2017 at 8:57 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    wow, that's the same set for most Toyota trucks, except for the 95-04 Tacoma, haha
  17. Oct 1, 2017 at 9:46 AM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Negative, or at least not the biggest
    2nd gen tacoma has 318mm rotor
    One upgrade is 4th gen 4runner/ gx470 338mm rotor and 13wl calipers
    Next upgrade is 5th gen 4runner/ gx460 338mm rotor and 14wa calipers (rotor is thicker and caliper has bigger pistons, 2-3mm can't remember)
    Both are bolt on upgrades as long as you have 17" wheels, pretty sure it's bolt on for first gen as well.
  18. Oct 1, 2017 at 9:17 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    well, that's still bigger than the 199mm Tacoma/v1 1st Gen Tundra and the 231mm v2 1st Gen Tundra :)
  19. Oct 3, 2017 at 2:13 AM
    The_Sahara_Man_FJ80
    Ish
    Glad people joined this discussion!! My brakes are still around 40% so I dont really need to do anything for the time being..
    As for the Tundra brake upgrade, I'd need more clearance for the calipers than my 16" Welds allow.. 17" beadlocks in the future, possibly after I get closer to my desired 6" lift..
    Cheers guys
