I found the best speakers!!!
Discussion in 'Audio & Video' started by 1tacoplease, Mar 23, 2009.
  1. Mar 23, 2009 at 1:00 AM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    Too bad they rattle the crap out of my access doors! I have already dynamatted and am looking for any other options or suggestions. I am running the MB Quart all the way around. Excellent speakers, we just have weak doors.
  2. Mar 23, 2009 at 1:03 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    not the doors, its the baffles the speakers are mounted on. You can pick up a good set at Tacotunes or make your own out of MDF wood
  3. Mar 23, 2009 at 1:16 AM
    1tacoplease
    Temecula
    And that would eliminate the rattling?
  4. Mar 23, 2009 at 1:22 AM
    DanGer
    hopefully, that was/is my problem. especially if you have dynamatted and still have the rattling, my guess would be the baffles. What baffles did you use?
  5. Mar 23, 2009 at 2:47 AM
    ComaTosin
    ComaTosin The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    contact mr marve. he has nice baffles.
    should help eleminate your issues
  6. Mar 23, 2009 at 3:28 PM
    1tacoplease
    Temecula
    I used the stock baffles if any. I am trying to dynamat more and even dynamat the seatbelt contraption because most of the rattling is coming from there. I', also filling the doors woth poly-fil which will hopefully help. If that doesn't work, then I'll have to purchase the baffles and if that doesn't help then i am S.O.L. unless anyone has any other suggestions???
  7. Mar 23, 2009 at 7:52 PM
    Coheednme13
    Coheednme13 Well-Known Member
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    you can dynamat the rear of the plastic panel and this can help with vibrations. Also if you do get some baffles put a layer of non-hardening modeling clay between the baffle and the metal and tighten them down and this will eliviate some of the rattles
  8. Mar 24, 2009 at 9:52 AM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    There's stock baffles??
  9. Mar 24, 2009 at 10:21 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    Authorized Hybrid Audio Technologies Dealer (www.hybrid-audio.com) ARC Audio amplifiers, subs, processors now available! Helix Processors now available! For you super high end guys Brax amplifiers will be available soon! (PICS HERE and new website coming soon with Subwoofers, Amplifiers, Wiring Kits)
    Once I find where the rattle is coming from I use the little stick on felt discs between the surfaces to eliminate the noise. (you can find them at the hardware store or Walmart)
  10. Mar 28, 2009 at 3:59 PM
    1tacoplease
    Temecula
    Are there stock baffles? The poly-fil and the dynamat helped but I can still hear a little rattling. I've heard you're the expert, Mr Marv, so what else are your reccomendations. It's slight rattling and I don't know if I'm being a perfectionast but when I turn it up louder than necessary, it does rattle, and occasionally with a dee bass song.
  11. Mar 29, 2009 at 9:50 AM
    Mr Marv
    Marv
    The stock baffle is actually part of the stock speaker. Did you just cut the old speaker out and screw the new one to that? If so I would start by replacing it with the proper baffle. Also, since you mentioned "when I turn it up louder than necessary, it does rattle, and occasionally with a deep bass song" I'm thinking there is a possibility the noise is coming from the speaker itself (some speakers can experience "tinsel lead slap" or you could be on the verge of bottoming it out from pushing it too hard or trying to play it too low). BTW, what size speaker is it and where is your high pass filter set?
  12. Mar 29, 2009 at 2:55 PM
    1tacoplease
    Temecula
    I am currently running 6.5 MB Quart mid range drivers that come with their own crossover. I'm also running 6X9 cMB Quart components in the front and I love th sound they produce. Since they both come with crossovers, I turned the high pass filter off on my head unit.
    I had them installed through a car audio place so I don't know if they used any baffles at all???
  13. Mar 30, 2009 at 8:38 AM
    Mr Marv
    Marv
    The passive crossovers that come with the components do not provide a high pass for the mid so you need to turn that filter on in the headunit (or on the amp) to reduce the amount of bass going to speakers that are not designed to play that low. :)
  14. Mar 30, 2009 at 6:47 PM
    jgarcia.mpa
    jgarcia.mpa Well-Known Member
    SoCal
    09 Tacoma DC TRD Sport
    as mentioned, the rattle is most likely the baff issue or maybe you didnt tighten it all the way, a little loose and with some bass it will rattle. also make sure all your clips on the door are on. if they arent you will rattle like crazy
  15. Apr 6, 2009 at 4:46 PM
    1tacoplease
    Temecula
    The poly-fil and dyno mat pretty much covered the rattling. When I turn it up while the windows are open on the freeway and I get off the freeway, I can hear the rattling. It doesn't bother me aymore but Do you all think it's worth it to get some baffles anyway?
