I got a flat tire should I replace all 4 tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Feb 20, 2024.
  1. Feb 21, 2024 at 8:38 PM
    Sh56
    Sh56 [OP] Well-Known Member
    Shara
    2022 Lunar Rock Tacoma TRD off road
    So the rear tires wear out faster than the front tires in tacomas?
  2. Feb 21, 2024 at 9:47 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    All things being normal, you are in a full time rear wheel drive vehicle... so rear tires would tend to wear faster.
    Unless one drives like these morons that race towards a red light and then slam on the brakes then whine about gas mileage...
    But even then - rear would likely wear faster...
    (I sense a triggering event somewhere...)
    Chew likes this.
  3. Feb 21, 2024 at 10:04 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    If your tires are less than 50% worn, I wouldn't worry about it.
    Over 50% - two new ones on the same axle.
    Over 75% - four new ones.
    If you make it to 120% wear then you are the kind of guy that should probably replace a spare too. ;-)
