I got a little fog light in my moisture
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CroResident, Feb 22, 2016.
  1. Feb 22, 2016 at 5:49 AM
    CroResident
    CroResident [OP] Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    2015 tacoma 4x4 DCSB
    A few months ago i began to notice moisture collecting inside of my fog light on the passenger side. i removed it, and dumped the water out and reinstalled it. every time i washed my truck, it would have quite a bit of water in it. i went to the dealer last week and got a brand new one. The new one is currently collecting moisture inside of it just like the old one did. :annoyed:
    Has anyone else experienced this and if so how did yall go about correcting this issue?
  2. Feb 22, 2016 at 10:34 AM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    are the bulbs stock? This happened to me only after I replaced the factory bulbs with LEDs. If they are stock I would just have the dealer replace it again
    Fenwick1993 and DustStorm4x4 like this.
  3. Feb 22, 2016 at 10:36 AM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Read the title and thought it was pretty funny. Maybe you were tired when you posted. Should it read "I got a little moisture in my fog light"?
    scottalot and Crom like this.
  4. Feb 22, 2016 at 10:42 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Mine don't leak that I know of, they just move around like they are cheap as hell.
  5. Feb 22, 2016 at 11:38 AM
    Tacorazy
    Tacorazy Well-Known Member
    Utah
    2014 Barcelona DCLB Sport
    I think OP meant what he wrote:)
  6. Feb 22, 2016 at 11:51 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    #warranty
  7. Feb 22, 2016 at 11:52 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    They're sealed pretty well.
    I have to assume that it isn't the housing that is the issue now that's it happened twice on separate housings.
    Check the bulb is seated correctly and all of that stuff.
  8. Feb 22, 2016 at 1:06 PM
    CroResident
    Nick B
    2015 4X4 DCSB
    im running aftermarket bulbs in them. the driver side never leaked and im using the gasket that came with the aftermarket bulbs on the driver side (the side thats not leaking)
    nope haha thats like sinking your truck in the mud and someone says "hey you went hit the mud last night?" and then you reply by saying "yeah, i got a little tires in my mud"
    with the first housing, i was using the gasket that came with the aftermarket bulb. when i got the new housing, (which also came with a new bulb), i used the gasket from the new one when i installed my aftermarket light in the new housing which is currently leaking. i pulled the new housing yesterday and dumped the water dropplets out through the blue "plug" on the back of the assembly and reinstalled it. it already has moisture built up inside of it. :help:
    Shmellmopwho[QUOTED] likes this.
  9. Feb 22, 2016 at 1:49 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Mines been completely submerged and the bulb apparently really likes the water and refuses to separate with it.
  10. Feb 23, 2016 at 3:51 AM
    CroResident
    Nick B
    2015 4X4 DCSB
    both of my foglights on mine have been under water once or twice and now the driver side has never leaked. the passenger side foglight keeps getting moisture in it. im sure theres got to be someone else on this forum whos had this problem.....
  11. Feb 23, 2016 at 8:59 AM
    Toy1985gc
    Toy1985gc Well-Known Member
    G
    2020 TRD Sport 4WD DCLB Tech Pckg Cement
    3 & 1 leveling kit 32 BFG KO's x17 Method Roost wheels/ TRD Skid
    Replace gasket on bulb- you also must make sure you get moisture out 100% before installing new gasket. I got MacGyver cut about 1-2 feet of garden hose. Removed bulbs- stuck hose in place and than had blow dryer on other end for 1-5 min. Moisture was gone-than through in some silica packs (taped to wire and left ) left the packs in housing for about 1-2 hours to ensure no more moisture. Even if you cant see it- its there (this more noticeable in headlight) . Installed bulbs with new gasket- no issues.
    NeedmoreTaco likes this.
  12. Feb 23, 2016 at 10:15 AM
    CroResident
    Nick B
    2015 4X4 DCSB
    you have a good point there. i may not have removed all the moisture from the housing before switching gaskets. ill let it air out. preciate the helpful info!
  13. Feb 23, 2016 at 10:32 AM
    Toy1985gc
    G
    No problem bro- I had exact same issue and some members shared info with the silica packs- works great! I think you should be find with just running some hot air in the fogs without adding silica packets since the housing pretty small. Actual headlight itself is when i needed to use silica packets to get moisture out 100%. Keep us posted on progress
  14. Feb 23, 2016 at 12:45 PM
    CroResident
    Nick B
    2015 4X4 DCSB
    hahah thats that attention getter!
    scottalot[QUOTED] likes this.
  15. Feb 23, 2016 at 12:48 PM
    T4RFTMFW
    I just noticed that.
    OP you're drunk! ;)
    CroResident[OP] likes this.
  16. Feb 23, 2016 at 12:58 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    i had water come in from the adjustment knob,dried it out ,a little silicone, done . no more water.
  17. Feb 23, 2016 at 1:10 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    My passenger fog gets moisture too. Noticed it glared toward outside a bit and found one of 3 tabs on bulb is very difficult to seat fully. It'll turn and feel locked in when it really isn't. Had to press in really hard against seal while turning.
    I'm not dealing with blower or desicant to get vapor out myself. Dealer can fix/replace as long as I'm in warranty.
  18. Feb 24, 2016 at 4:01 AM
    CroResident
    Nick B
    2015 4X4 DCSB
    aw mais! cant have nothin nice i tell you what
  19. Feb 24, 2016 at 4:07 AM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    If you installed a new one then we can rule out the seal being bad. It's more then likely the seal on the bulb. I had the same thing happen to me. I purchased new bulbs and it fixed the issue. But......Instead of just dumping the water out and reinstalling you need to make sure you get it all out. Leave the bulb out of it and lay it on the ground. Plug in a hair dryer and point it toward the hole where the bulb goes. Don't put it too close though or you'll melt plastic. This will dry out all the water in the casing so you won't have any moisture in there at all.
